Hi JazzCNC,
Thanks for this. What is the problem with DC motors for the spindle? I'm going to buy one of the 3040's to learn on, then look to build a serious one for milling con rods, etc. What type/size/power cnc do you use? Can you recommend a kit/spec that will handle aluminum blocks?
Gary
27-04-2015 #2
The use Carbon brushes and burnout in no time. Complete rubbish best avoided.!!
For milling aluminium you'll want a spindle that can run between 7000rpm and approx 18000 dependent on tool size. Water cooled 2.2Kw works fine for cutting aluminium and suits routing softer materials as well with it's 6000 to 24000rpm range.
27-04-2015 #3
30-04-2015 #4
Hi silyavski and JazzCNC,
I am definately looking at better quality machines now and increased my budget considerably.
Gary
Need advice for 4*8 cnc machine build
By msacnc in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 18-10-2014, 01:18 PM -
BUILD LOG: Advice sought on new Mill build
By embraced in forum DIY Mill Build LogsReplies: 40Last Post: 02-10-2014, 05:36 PM -
Initial workpeice tooling set-up instructions using a pendant controller type machine
By Nthkentman in forum Machine DiscussionReplies: 25Last Post: 30-08-2014, 08:33 PM -
BUILD LOG: my router build - advice needed
By thomashomer1986 in forum DIY Router Build LogsReplies: 10Last Post: 02-12-2013, 11:45 PM -
Best Type of Machine to Build?
By Kevin in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 05-08-2009, 02:50 PM
