    ian isn't welsh jazzcnc hes from bangor northern Ireland but he did go to England to have it machined to level it or make it flat or sopmthing like that lol email address is sent in pm
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I would take your email address down as you are open to the spammers or put some spaces and (dot) or (and) Clive
    Quote Originally Posted by feetsy View Post
    Ask him and I think you'll find he is from Welsh stock. He came to England to visit family and Pick the machine up from me. I built all of it lock stock n barrel in Sunny Yorkshire, England.!!. . . . Ian built the control box and did the wiring.
  5. #4
    ian bell you call him
  6. #5
    Yes Ian Bell trust me Buddy I built that machine all of it. . . . . Check this out.!!! (HemsworthLad is me.!!)
    http://www.cnczone.com/forums/cnc-wo...ee-beasty.html
    I even have the offcut from the Gantry extrusion still kicking around.!
    The X & Y are belt driven with long axis belts being under the bed with 2 belts running down each side with pulleys on bars at each end. There's a single motor connecting to one of the rods thru a reduction system with I think 6:1 ratio.
    I orginally built it with a 3:1 reduction but it was too fast so decided to increase resolution, as you'll see if you look at the aluminium pulley on the Y axis and compare with pics on cnczone which is steel.! . . The little Bugger still goes like the clappers.
    This was the last belt drive machine I built. Now all machines use ballscrews from china as there's very little price difference.
    With just one belt so going slow.!!
  7. #6
    lol small world mate ill say to him hahaha do you have plans for that machine
  8. #7
    Anyone got plans for machine I can sort electronics
  9. #8
    Go back and read my first post again.!! . . . . You won't find any plans worth the effort.
    Going to be quite blunt here in an attempt to make you sit back and think before doing or BUYING anything yet.!!
    If you haven't got the engineering skills or the abilty to workout a machine design after looking thru this forum then you haven't got what it takes to build a CNC machine.!! This is why I ended up building Ian's Machine, he had the skills but not the Knowledge or equipment.
    Plans no matter how good don't guarantee you will build a machine worth the effort if you don't have a certain amount of knowledge to help assist. You my friend have NOT learnt enough yet to even be thinking about building.
    So my advise to you is very Clear and to the point.!! . . . Don't Bother.!! . . . Wait, learn the Knowledge of what is needed by reading thru the forum and asking questions.
    Don't Buy anything yet. Especially on the Electronics side. Stay well clear of Ebay and the temptaion to buy any Kits etc. They are rubbish and you will regret any purchase you make now before knowing what machine your actually building.
    Look around the forum decide on a machine design then ask questions. If you rush then you will most likely fail or end up build a pile of unreliable rubbish.
  10. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. How to carve a bowl out of wood on a 3 axis machine.
    By Aaron74 in forum General Discussion
    Last Post: 19-08-2017, 07:11 PM
  2. wood supplier.
    By D-man in forum Woodwork Discussion
    Last Post: 10-04-2015, 08:48 PM
  3. RFQ: Wood CNC routing service (wood Letters)
    By coujin in forum Projects, Jobs & Requests
    Last Post: 16-02-2015, 03:35 PM
  4. Detailed plans needed for wood CNC machine
    By woodspiral in forum Open Source Designs & Plans
    Last Post: 08-02-2014, 11:44 PM
  5. BUILD LOG: Wood router machine, 600x400
    By troyboy1 in forum DIY Router Build Logs
    Last Post: 05-12-2012, 12:47 AM
