Thread: machine for wood only
27-04-2015 #10
Yes Ian Bell trust me Buddy I built that machine all of it. . . . . Check this out.!!! (HemsworthLad is me.!!)
http://www.cnczone.com/forums/cnc-wo...ee-beasty.html
I even have the offcut from the Gantry extrusion still kicking around.!
The X & Y are belt driven with long axis belts being under the bed with 2 belts running down each side with pulleys on bars at each end. There's a single motor connecting to one of the rods thru a reduction system with I think 6:1 ratio.
I orginally built it with a 3:1 reduction but it was too fast so decided to increase resolution, as you'll see if you look at the aluminium pulley on the Y axis and compare with pics on cnczone which is steel.! . . The little Bugger still goes like the clappers.
This was the last belt drive machine I built. Now all machines use ballscrews from china as there's very little price difference.
With just one belt so going slow.!!
How to carve a bowl out of wood on a 3 axis machine.
By Aaron74 in forum General DiscussionReplies: 13Last Post: 19-08-2017, 07:11 PM -
wood supplier.
By D-man in forum Woodwork DiscussionReplies: 11Last Post: 10-04-2015, 08:48 PM -
RFQ: Wood CNC routing service (wood Letters)
By coujin in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-02-2015, 03:35 PM -
Detailed plans needed for wood CNC machine
By woodspiral in forum Open Source Designs & PlansReplies: 16Last Post: 08-02-2014, 11:44 PM -
BUILD LOG: Wood router machine, 600x400
By troyboy1 in forum DIY Router Build LogsReplies: 2Last Post: 05-12-2012, 12:47 AM
