Thread: Hello from Derry!
30-04-2015 #4
Hi Clive,
It sure is nice to get such a warm reception and a gracious offer of assistance, thank you very much.
I have been on a few forums in my day so I'm sure I will get on just fine!
The only thing resembling branding on this is the 6040 name from the eBay listing.
The specs are as follows;
- Effective working travel: 580(X)mm*400(Y)mm*65(Z)mm
- Frame materials: 6061 aluminum alloy + 6063 Industrial aluminum
- Driving units X,Y&Z: 1605 ball screws
- Sliding units Y axis: Dia.20mm chrome plate shafts
- Sliding units Z axis: Dia.13mm chrome plate shafts
- Stepping motor type: 57 two-phase 3A ,super-low noise ,NEW
- Spindle motor: 800W water cooling VFD spindle, 24000RPM
- Principal axis collet: ER11/3.175 collet
- Spindle speed: 24000rpm/min (PWM stepless speed regulation)
- Control unit: Triaxial one-piece drive + ring variable power + PWM speed
- Control unit: Toroidal transformer + PWM psu module + TB6560 drive board
- Control Software: Mach 3
I have the 4-Axis Model but I intend to use only 3 most of the time so I haven't experimented with the 4th yet.
At the minute I'm using Mach3 and PyCam and Adobe Illustrator.
Thanks again,
Kevin.
