    If i still use the RHS 200x80x4 and mount the linear rails one on the top and one on the bottom the center distance will be 260mm, so should be fine.How about the outer face distance between the linear rails blocks? Is 220mm enough?
    If X axis is what moves Z left right -yes. On long Y axis - the gantry legs min 250mm, i would say at least 300mm step is right. I see you plan to use 3 bearings there which is even better. When 3 bearings are used they have to be precisely mounted otherwise it could get worse
  2. BUILD LOG: Ar last!!! Started my Gantry 3-Axis CNC Build
    By MikeyC38 in forum DIY Router Build Logs
    Last Post: 16-06-2018, 11:29 PM
  3. BUILD LOG: New build - fixed gantry mill using extruded profile
  4. Sugestions For machines pleas
    By Kai in forum Milling Machines, Builds & Conversions
    Last Post: 07-04-2011, 10:18 PM
