Thread: Gantry Router
    here is the original solution https://cockrum.net/cnc.html
    Thanks for the info.....the cross linked cable is interesting
    Stevep
    Quote Originally Posted by stevep View Post
    Stevep
    It also doesn't work very well so don't waste your time and effort.!!
    This can be done without changing drives using an arduino and tacho's or encoders on each screw then compare readings and if large difference then send a signal to the input on controller to e-stop.
    But for the cost and complexity you may has well just buy AM882 drives that have stall detect and will most likely be much better than the drives you have already.
  2. Cast aluminium gantry router
    By jrcast in forum Gantry/Router Machines & Building
    Last Post: 17-02-2017, 08:13 PM
  3. Small Gantry Router
    By mike os in forum Gantry/Router Machines & Building
    Last Post: 08-01-2015, 07:02 PM
  4. RFQ: RQF: Router Gantry plates
    By lateAtNight in forum Projects, Jobs & Requests
    Last Post: 27-12-2012, 04:56 AM
  5. BUILD LOG: Fixed Gantry Router
    By lateAtNight in forum DIY Router Build Logs
    Last Post: 28-05-2009, 11:30 PM
