Thread: Gantry Router
It also doesn't work very well so don't waste your time and effort.!!
This can be done without changing drives using an arduino and tacho's or encoders on each screw then compare readings and if large difference then send a signal to the input on controller to e-stop.
But for the cost and complexity you may has well just buy AM882 drives that have stall detect and will most likely be much better than the drives you have already.
Cast aluminium gantry router
By jrcast in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 17-02-2017, 08:13 PM -
Small Gantry Router
By mike os in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 08-01-2015, 07:02 PM -
RFQ: RQF: Router Gantry plates
By lateAtNight in forum Projects, Jobs & RequestsReplies: 1Last Post: 27-12-2012, 04:56 AM -
BUILD LOG: Fixed Gantry Router
By lateAtNight in forum DIY Router Build LogsReplies: 24Last Post: 28-05-2009, 11:30 PM
