I went to the Tig route so that I could weld Steel but also be able to weld Aluminium, Although I still haven't done that as yet. Tig welds look nice and are strong But mig can make beautiful looking welds too , but Tig is harder to learn because you have a foot control (Normally) the torch in one hand and the welding rod in your other hand so each is doing something.
Mig is more forgiving when welding where as with Tig everything has to be as clean as possible to get a good weld, Firstly cleaning the weld material with Acetate before welding.
I am still learning and most of the time things look okay and stay stuck together, well I have blown through material that is thin so thicker material is easier to learn welding on.
Don't forget to budget for a welding helmet and Good Welding gloves and always wear clothes that cover you up. welding can cause Sunburn type burns on your skin.
Most definitely look on the forums because I didn't realise that welding zinc coated items e.g. Nuts and bolts is dangerous to your health so grind Zinc off because you do it and wear a mask if not sure.
Tig is a Higher cost than Mig because you have to use a different gas which the Price is higher using Argon and the Startup costs are higher. I brought a cheaper Chinese tig from ebay and Its fantastic and I still love how much you can make with these things. but still cost a few Hundred pounds but I want it to last for years to come.
Our local college at Coalville does a Welding course sometimes and that is worth looking at your local college first to see if there is a course and they will teach you but also let you get your hands on the kit before you buy.
I brought a rent free bottle from Barnett welding supplies a small family run business and you pay for the bottle for the first time but then it is the Delivery and the cost of the gas.
http://barnet-welding.co.uk/
The gas goes pretty quickly to a bigger bottle is better it lasts in the bottle so can still be stored.
Rob
09-11-2017 #2
10-11-2017 #3
With my Smashweld 180 MIGs, using appropriate gas and wire, I weld Steel, Stainless Steel, Cast Iron, Brass, Bronze, Copper and Aluminium, sometimes I also MIG Braze Steel.
I don't know why people think MIG is more limited than it is.You think that's too expensive? You're not a Model Engineer are you? :D
17-07-2018 #4
I am new to welding - been at it about a year now.
Started off with stick inverter, then bought a TIG torch and bottle of Argon to go with it.
I found I wasted too much gas having to control it manually with a knob on top of the torch, and lift TIG was a pain.
Then I upgraded to a DC TIG.
I love it. It is a very clean process. Minimal if any cleaning afterwards. No sparks so I can do it in the garage. The metal has to be very clean. No welding rusty panels for MOT.
I haven't got a foot control. I have been told it is not necessary if only welding steel.
TIG allows a great range of control I have welded everything from 7mm plate and 3mm box section, to the tips of Stanley knife blades together.
I still have a lot to learn. I am fairly successful at sticking the metal together and getting pretty (and I hope strong) welds. My biggest problem is metal distortion. Maintaining the accuracy would be my biggest concern if I was to tackle a frame for a CNC.
17-07-2018 #5
To start I would go with a stick welder (arc welding)
For the price point - say £150 to £200 you can weld all types and thicknesses of steel. a mig to weld over 5mm you are looking at some serious investment + the bottled gas ££££
You can often buy a TIG torch for many of the good Arc welders and do TIG at a later date - but you will need gas ( Argon or Argon Helium mix - this can be used on both steel and aluminium)
Many cheap MIG machines claim they can weld 5mm+ thick but they are really poor welds as the metal does not pool enough to create good adhesion.
You don't need gas to use stick welding
The welding electropdes (sticks) are the cheapest consumable. Normally depending on the thickness of the steel usually determines the thickness of the rod - however people can have preferences - i.e. I like using 2.5 or 3.2mm for most welds unless less than 1.5mm thickness
Stick welding can weld through rust paint ect (however - all steel should be cleaned prior to welding otherwise you will get foriegn objects and porosity that weaken the weld) - but it is the most forgiving
Go watch the videos @ weld.com and follow some of the instructions
There are things like DC+ or DC- (which way the torch and the return is plugged in)
How many amps to use for different thicknesses
Types of weld angles and joints
Type of electrodes (sticks) i.e in UK ppl mainly use 6013 however in the states they use 7018 - they differ as to how much penetration and what position you can weld.
hope this gives you something to look at :o)
MikeLast edited by Hulksmash; 17-07-2018 at 05:55 PM.
The Following User Says Thank You to Hulksmash For This Useful Post:
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
RFQ: I need apx 100 brass tubes being cut down
By Chance1234 in forum Projects, Jobs & RequestsReplies: 0Last Post: 02-04-2014, 02:05 PM -
Manufacturer of SS Fittings and Tubes - GT Metals and Tubes
By gtfittings in forum Manufacturer NewsReplies: 0Last Post: 19-12-2013, 01:44 PM -
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
Straightness of steel/alumunium box section
By Jonathan in forum Linear & Rotary MotionReplies: 50Last Post: 17-09-2010, 07:53 PM
