    Quote Originally Posted by grain_r View Post
    I brought a rent free bottle from Barnett welding supplies a small family run business and you pay for the bottle for the first time but then it is the Delivery and the cost of the gas.
    http://barnet-welding.co.uk/
    I did similar, but used Hobbyweld as they have a supplier very near to me. My last bottle of argon mix lasted over 3 years, which is better than the disposables (£ for £) which can also empty themselves spontaneously.
    With my Smashweld 180 MIGs, using appropriate gas and wire, I weld Steel, Stainless Steel, Cast Iron, Brass, Bronze, Copper and Aluminium, sometimes I also MIG Braze Steel.
    I don't know why people think MIG is more limited than it is.
    IanT's Avatar
    Lives in Gnosall (Stafford), United Kingdom. Last Activity: 09-12-2023 Has been a member for 6-7 years. Has a total post count of 6.
    I am new to welding - been at it about a year now.
    Started off with stick inverter, then bought a TIG torch and bottle of Argon to go with it.
    I found I wasted too much gas having to control it manually with a knob on top of the torch, and lift TIG was a pain.
    Then I upgraded to a DC TIG.
    I love it. It is a very clean process. Minimal if any cleaning afterwards. No sparks so I can do it in the garage. The metal has to be very clean. No welding rusty panels for MOT.
    I haven't got a foot control. I have been told it is not necessary if only welding steel.
    TIG allows a great range of control I have welded everything from 7mm plate and 3mm box section, to the tips of Stanley knife blades together.
    I still have a lot to learn. I am fairly successful at sticking the metal together and getting pretty (and I hope strong) welds. My biggest problem is metal distortion. Maintaining the accuracy would be my biggest concern if I was to tackle a frame for a CNC.
    To start I would go with a stick welder (arc welding)
    For the price point - say £150 to £200 you can weld all types and thicknesses of steel. a mig to weld over 5mm you are looking at some serious investment + the bottled gas ££££
    You can often buy a TIG torch for many of the good Arc welders and do TIG at a later date - but you will need gas ( Argon or Argon Helium mix - this can be used on both steel and aluminium)
    Many cheap MIG machines claim they can weld 5mm+ thick but they are really poor welds as the metal does not pool enough to create good adhesion.
    You don't need gas to use stick welding
    The welding electropdes (sticks) are the cheapest consumable. Normally depending on the thickness of the steel usually determines the thickness of the rod - however people can have preferences - i.e. I like using 2.5 or 3.2mm for most welds unless less than 1.5mm thickness
    Stick welding can weld through rust paint ect (however - all steel should be cleaned prior to welding otherwise you will get foriegn objects and porosity that weaken the weld) - but it is the most forgiving
    Go watch the videos @ weld.com and follow some of the instructions
    There are things like DC+ or DC- (which way the torch and the return is plugged in)
    How many amps to use for different thicknesses
    Types of weld angles and joints
    Type of electrodes (sticks) i.e in UK ppl mainly use 6013 however in the states they use 7018 - they differ as to how much penetration and what position you can weld.
    hope this gives you something to look at :o)
    Mike
  5. The Following User Says Thank You to Hulksmash For This Useful Post:
  1. BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
    By grain_r in forum DIY Router Build Logs
    Last Post: 27-01-2023, 06:47 PM
  2. RFQ: I need apx 100 brass tubes being cut down
    By Chance1234 in forum Projects, Jobs & Requests
    Last Post: 02-04-2014, 02:05 PM
  3. Manufacturer of SS Fittings and Tubes - GT Metals and Tubes
    By gtfittings in forum Manufacturer News
    Last Post: 19-12-2013, 01:44 PM
  4. Maximum size of box section, Stacking box section, Construction Angle
    By andy586 in forum Gantry/Router Machines & Building
    Last Post: 01-02-2013, 05:29 PM
  5. Straightness of steel/alumunium box section
    By Jonathan in forum Linear & Rotary Motion
    Last Post: 17-09-2010, 07:53 PM
