You VFD documentation will probably tell you the current draw of the VFD. Some even suggest the cable size.
My 2.2kW states that it may draw up to 20 amps. Especially during motor startup.
May I suggest you get an electrician to help you set it up? You should not really just plug it into the wall without making sure that the wall socket you are using is ok for the currents you are going to be seeing. It is a fire hazard otherwise.https://emvioeng.com
The Following User Says Thank You to komatias For This Useful Post:
14-05-2015 #2
The ends for such cables are available separately, I'd go for the option of building your own cable, that way you can have manufacturer's specifications for all the components you use,
- Nick
The Following User Says Thank You to magicniner For This Useful Post:
14-05-2015 #3
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
FOR SALE: power supply
By Web Goblin in forum Items For SaleReplies: 0Last Post: 14-09-2014, 03:19 PM -
motor power and chinese spindles power HELP
By DigiSoft in forum Spindles & Drive MotorsReplies: 5Last Post: 17-09-2013, 12:17 AM -
rep power ???
By TrickyCNC in forum General DiscussionReplies: 11Last Post: 19-09-2012, 03:57 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
i need more power LOL
By Scott in forum General ElectronicsReplies: 2Last Post: 12-04-2010, 02:41 PM
