Hi - I'm new to this forum and it's an incredible resource for CNC machine builders.
I am looking for specific advice on how to go about establishing a level surface and straight reference line for mounting profile rails on a steel or aluminum box tube when you don't have the option of getting an accurate reference surface established via mill or surface grinder. I have a vertical mill with 24" bed travel, so I'm good for smaller parts or the entire z-axis of a gantry CNC machine.
I've read through the many posts on epoxy leveling. I have no issue going that route, but am thinking would prefer to use a dense filled epoxy (aluminum and/or stainless powder) for best compressive strength. I read some of Jazz's recommendation to use a mix of hand grinding and spot leveling, and I know how to hand scrape ways, but I don't have a large machinist's straight edge - just a 12 x 16" granite surface plate.
I would like to mount my rails on the side of the steel box tubes, so a self-leveling epoxy pour is out. But if I can get a level and straight alignment on the 2 side box tubes, I can certainly shim and epoxy bed the 2 box tubes with attached profile rails onto the machine frame once they are aligned parallel to each other.
Regards,
Chris Krumm
Boxford TCL 160 tool alignment
By Saracen in forum Boxford LathesReplies: 2Last Post: 05-11-2014, 10:28 PM -
Revised G-Code Quick-Reference / Cheat Sheet
By DanielF in forum Machine Control SoftwareReplies: 2Last Post: 20-02-2014, 11:14 AM -
Assembling & alignment precision concerns
By njcook in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 17-08-2013, 05:19 PM -
Mini Lathe alignment
By pequod in forum Lathes, Lathe Rebuilding & ConversionsReplies: 2Last Post: 29-06-2009, 06:40 PM -
Schematic Symbol Reference
By Lee Roberts in forum General ElectronicsReplies: 1Last Post: 23-01-2008, 03:23 PM
