Thread: What 'decent' Milling machine?
30-05-2015 #51
30-05-2015 #52
yes that is the one
https://emvioeng.com
31-05-2015 #53
What is this worth?
http://www.ebay.co.uk/itm/Denford-Tr...item3aa95b6db3
This might give me a starting point at least. Id be willing to spend a bit more for 'better' but short of someone building me a custom machine (hint hint Jazz), not a lot of options ready to go. Im loathed to spend as much as £5 - 8K on a Syil or similar unless its felt that its worth it .... dont believe it is from advise thus far.
01-06-2015 #54
I have a little Denford and it's excellent for what I want to do. A Triac would be nice as it's bigger, about the size of my VMB, but I don't have room for it. Unless you are very particular I'd have thought a Triac would be a good buy. When I got my Novamill I was thinking of converting an X1 or buying a KX1, but the Denford knocks those small machines into a cocked hat, it's just in a different league. A Bridgeport is great, but takes up lots of room, and is very very heavy! I would guess that with a Triac you would get the same accuracy as a Bridgy but won't be able to shave off metal as the same rate.
As for what it's worth, things are worth what people will pay. This particular one is not in an auction but you could try making an offer. I think eBay gives you a facility to see previous deals on similar items, so you could see what's been paid in the past? The price looks a bit high to me but I've seen some high prices for Denfords on eBay.Last edited by JohnHaine; 01-06-2015 at 10:28 PM.
02-06-2015 #55
02-06-2015 #56
I think quite a bit technically is. Denford have been pretty good at providing documentation and so forth. So, in principle, you can probably wire a breakout board to those drives, if they're working.
However, the electronics are often pretty old and basic. Most of the conversions I've seen seem to replace everything, except perhaps the motors and maybe the transformer.
Personally, I'd budget for replacing all of the electronics.
02-06-2015 #57
02-06-2015 #58
Wondering if this is the same mill?
http://www.mycncuk.com/threads/1605-Denford-Triac-Mill
Seems a lot might be reusable. So budget for a cheap retrofit? Budget for going servo versus stepper? Info welcome, many thanks.
02-06-2015 #59
Depends on how old and what's inside.? Often if converting your better just replacing control and the drives with modern stuff. You'll have a far better performing machine.
The AC Transformer can be re-used but often the Caps and Bridge rectifier are on one of the boards your removing so you'll need to make a little board with new caps etc or use another PSU.
For this reason I prefer to use a new often higher voltage toroidal supply has the steppers are often well under performing. Along with smaller Switch mode PSU for Relays etc to save messing around with differant size Caps etc for differant DC voltages required. The stock transformer gives several AC voltages.
The Spindle speed controller can be re-used but you'll need Controller or BOB that can provide 0-10V signal.
The Contactors and Relays can often be reused, as can most of the other bit's n bobs inside.!
Not difficult to do but Not something I'd encourage anyone who as NO experience to take on.!!
02-06-2015 #60
FOR SALE: 240v decent electric filter
By DrNik in forum Items For SaleReplies: 3Last Post: 16-03-2015, 12:30 PM -
WANTED: cnc milling machine
By bigred5765 in forum Items WantedReplies: 14Last Post: 25-04-2014, 11:08 PM -
eBay: Looks a decent little machine
By EddyCurrent in forum Items On eBay UKReplies: 13Last Post: 12-09-2013, 04:55 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
First CNC milling machine help
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 05-09-2011, 10:06 PM
