23-05-2015 #9
Relays are very simple. You have signal output on your board - you could add external relay for 2$ each. You only need to have the output so it triggers the relay with 5-24v, having in mind that the LPT breakout boards have limited number of inputs and outputs and the more industrial boards could have 50 digital inputs or outputs or even 100.
Some boards have integrated a couple of relays for the coolant, spindle and so, some dont have. As i said relays are very cheap.
Thats all you will ever need to know.
FOR SALE: leewood 3 axis controller from an isel 3 axis cnc
By nobby in forum Items For SaleReplies: 1Last Post: 24-09-2014, 09:08 AM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM -
Heelp! Dual axis steppers.. Losing steps.. Pulling hair out..!
By fasteddy in forum Motor Drivers & ControllersReplies: 9Last Post: 14-05-2010, 02:32 PM
