09-01-2016 #2
I have
Do you think there is an improvement in mounting carriages on the side (position A : on the green plate on the pic) or behind the yellow plate (position B), I would say the position A is better as it is wider it doesn't reduce the working area and the external distance is 340mm instead of 200mm .but i can be wrong...
question 1 : For you what is the best position for carriage A or B ?
Question 2 for this axis 800mm wide do you vote for a 1610 or 2010 ?
Thanks for your advices
P-ALast edited by pierantoine; 09-01-2016 at 03:25 PM.
07-03-2016 #3
i will take the steel frame route.
there is a useful post where i've seen nice frames from Dean and Boyan... i've made a mix :-)
I've seen a post where Dean suggest 2 fixed ends for the ball screw
http://www.mycncuk.com/threads/8490-...x750x200/page3
"To give you an idea I recently built a Slaved axis 4x4 router with 20mm Dia 10mm pitch screws 1700mm length Fixed/Fixed ends with 2 x 3.1Nm steppers"..
the 2 beams supporting the rails can be slightly not parralels so an adjustment for fixed ends must be adjustable.
if you have made something like this i'm really interested.. thanksLast edited by pierantoine; 08-03-2016 at 12:18 AM.
16-05-2016 #4
Thanks to every one after many hours of reading here is what I will make.
Here is the final version before starting the build and ordering the parts...
the green frame could be made on a bench before the red / yellow...
adjustable mounting of the ends...
the green plate is 15mm ground plate maybe. i'have found 20mm but is not ground...
between collet and frame (without bed)
218mm Z up an 68 mm Z Down.
For the plates 40, 50, 51 supporting the carriage would it be better to have 20mm not ground or 15mm ground ?
Do you have any comments before I start the build ?
Many thanks..Last edited by pierantoine; 16-05-2016 at 02:28 PM. Reason: Any comments before starting the build ?
17-05-2016 #5
15 Ground, if you can't machine the mating surfaces.
Orange plate not needed, punch down from plate 51 to the nut (see pic example).
Or, if you really want to create a box, punch down from plate 51 to plate XX but make orange plate an X shape, locate nut in the center of the X (less material than current orange plate).
.MeLast edited by Lee Roberts; 17-05-2016 at 10:14 PM.
The Following User Says Thank You to Lee Roberts For This Useful Post:
08-01-2017 #6
08-01-2017 #7
Yes for acceleration reasons but at that length your still high chance of whip with 16mm screw. And why would you need Higher acceleration than 20mm could provide.?
At this length 20mm is better suited and to improve things more go with 20mm pitch and use 2:1 ratio on the pulleys. Also have Fixed bearings at both ends.
This gives the advantage of lower screw speed and higher torque. The Fixed bearings make everything that little bit stiffer.
WANTED: 150mm dia x 15mm wall Ali pipe
By r0bsk1 in forum Items WantedReplies: 9Last Post: 12-06-2014, 04:19 PM -
Melbourne Andy CNC 1220x810 working area
By AndyGuid in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 17-04-2014, 11:41 AM -
WANTED: Profile rails, 600mm and 900mm
By Jonathan in forum Items WantedReplies: 2Last Post: 16-08-2011, 09:18 AM -
Stick with Ali profile or venture into plate?
By ecat in forum Metalwork DiscussionReplies: 14Last Post: 22-08-2010, 09:00 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM
