23-05-2015 #6
Hi Guys,
I was looking at using 50mm x 50mm x 4mm SHS steel tubing for the frame.
Silyavski, that is an interesting thought. I suppose I could do it in 100x100x4mm SHS. I will have to do the price calculations. I am planning to get all the pieces cut to the required lengths at the place I buy the steel so the size of the SHS is not really an issue.
Clive S, I had always planned to add feet to the frame.
Here is the updated design with the feet in place.
For the gantry I am going to look at how I get a ball screw between the rails of the Y axis.
I think I will put an I beam inside the RHS beam and then remove material to make a void. I have seen other person do this and it looks doable.
Requesting some feedback on steel frame design.
By Misc in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 15-12-2014, 02:49 PM -
expanding foam and steel frame
By Gytis in forum Metalwork DiscussionReplies: 11Last Post: 18-08-2013, 10:35 AM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM -
Steel frame for 8' * 4' cnc bed ?
By flanagaj in forum Gantry/Router Machines & BuildingReplies: 24Last Post: 18-10-2011, 08:57 PM -
Ideas sought to deburr a 5mm length of 5mm dia steel!
By HankMcSpank in forum General DiscussionReplies: 9Last Post: 22-03-2010, 08:48 PM
