28-05-2015 #12
No. Either do it like it is or redesign it completely for the other type of machine, where the bed is raised.
There is a reason most strong DIY builds use raised sides on the bed and the bed is bellow.
For a first build is not advisable to make the bed raised cause most possibly you will finish with a machine having a weak link somewhere at the gantry. Not that is not doable, just needs some careful considerations.
If you look at forums you will see all machines of these type are weak or crappy, even if they have ton of steel in it. Especially this is the case if you want to do aluminum.
Not to speak of the difficulties you wil encounter of aligning properly the long railsLast edited by Boyan Silyavski; 28-05-2015 at 06:05 AM.
Requesting some feedback on steel frame design.
By Misc in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 15-12-2014, 02:49 PM -
expanding foam and steel frame
By Gytis in forum Metalwork DiscussionReplies: 11Last Post: 18-08-2013, 10:35 AM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM -
Steel frame for 8' * 4' cnc bed ?
By flanagaj in forum Gantry/Router Machines & BuildingReplies: 24Last Post: 18-10-2011, 08:57 PM -
Ideas sought to deburr a 5mm length of 5mm dia steel!
By HankMcSpank in forum General DiscussionReplies: 9Last Post: 22-03-2010, 08:48 PM
