when i said above for the plates i meant the gantry.
What would be the square steel box profile size? I calculated it many times and for steel machine/this size especially/ is best to use bigger profile 100x100x3 or 4mm and simplify the structure. I say always 100x100 as it is the max that could be handled and cut at home using dry saw or small band saw.
The benefits are:
-simpler
-easy to cut at home
-easier to solder
-stronger
-less metal for the same strength so cheaper
You could read more here and see changing the table design leads to substantial savings http://www.mycncuk.com/threads/5302-...highlight=tony
In fact if you have the means the bigger is better here.
Requesting some feedback on steel frame design.
By Misc in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 15-12-2014, 02:49 PM -
expanding foam and steel frame
By Gytis in forum Metalwork DiscussionReplies: 11Last Post: 18-08-2013, 10:35 AM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM -
Steel frame for 8' * 4' cnc bed ?
By flanagaj in forum Gantry/Router Machines & BuildingReplies: 24Last Post: 18-10-2011, 08:57 PM -
Ideas sought to deburr a 5mm length of 5mm dia steel!
By HankMcSpank in forum General DiscussionReplies: 9Last Post: 22-03-2010, 08:48 PM
