Ralph Waldo Emerson
20-05-2015 #2
Always best to have a square machine, but if you're still out after days of tweaking and you're able to measure the discrepancies, you might consider software correction:
http://korovievskitchen.blogspot.co....on-in-emc.html
That link's for EMC (Linux CNC) - I imagine that there's also a way to achieve this in Mach.
Once again, there's no substitute for a mechanically accurate, well set-up machine, but if you're only able to make ham-fisted adjustments that aren't working for you, then this might be an option.
Wal.Last edited by Wal; 20-05-2015 at 12:35 PM.
20-05-2015 #3
Ralph Waldo Emerson
22-05-2015 #4
Bashed it straight, did a test, top male and bottom female with a -0.25 offset , fit was perfect.. sledge Hammer ftw !
Ralph Waldo Emerson
22-05-2015 #5
Do you have a vid of the system you used
Black Slate Engraving
By Leadhead in forum General DiscussionReplies: 4Last Post: 12-03-2020, 09:01 PM -
Dry Aluminium Cutting Problem
By Tenson in forum Tool & Tooling TechnologyReplies: 22Last Post: 29-08-2016, 11:41 PM -
Cutting Aluminium With A Cheapo 3020 CNC
By Pointy in forum Metalwork DiscussionReplies: 5Last Post: 05-05-2014, 09:59 AM -
The Journey begins.. new to me.. my first CNC - Black Cat
By Fivetide in forum Milling Machines, Builds & ConversionsReplies: 37Last Post: 22-10-2012, 05:48 PM -
Has anyone got/used a machine from Black-Cat-CNC?
By cjpwart in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 12-08-2012, 05:15 AM
