20-05-2015 #4
The folks on here quite often use Chai at liniermotionbearing2008 or BST at http://es.aliexpress.com/store/314742
With a machine 500 x 500 you might get away with one screw on X (others will chime in here) but if use two screws the choice is up to you, one motor driving both screws or two motors slaved.
Have a good read through some of the build logs to get ideas and copy if need be. ..Clive
Truss Structures - in larger gantry router design
By CharlesJenkinson in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 10-02-2014, 09:56 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
