Hi Ellis, welcome to the forum. For the size that you are building, and the materials you wish to cut, I personally think it would be worth thinking about a fixed gantry rather than a moving gantry. With a machine like that and 20mm rails and a single 20/25mm central ballscrew I think you could build a really rigid little machine that would suit your requirements, but would of course require a longer X axis. Good luck with whatever you decide, keep posting your designs and thoughts and some of the very experienced members here will offer all the help you need. G.
Truss Structures - in larger gantry router design
By CharlesJenkinson in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 10-02-2014, 09:56 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
