    1500??? No way. In worst case scenario that could be a great opportunity to change the control board with something like CSMIO/IP-M
    Thanks for the reply Silyavski. That sounds amazing. I haven't a clue how to fit that to a Boxford machine! Does it just plug in somewhere? Will it work with Boxford steppers and software??
    I'm a complete novice at this so any help hugely appreciated.
    I have no idea whats inside your machine, maybe somebody will help there. But basically you rip out the main board fit the new one inside or make a separate housing, read the manual of the new board, connect the stepper drives to the board, connect limit switches, connect buttons to inputs, map inputs in Mach 3.
    You will need Mach3 also. That's the program that most people use for CNC, its inexpensive , has great forum, ...
    If nobody knows more details, basically i will help you. You will need to open the machine control box? and take some pictures, of the board, drives and motors.
    Are these any use? They are integrated behind the machine.....
ID:	15428   Click image for larger version.
ID:	15427   Click image for larger version.
    Now, now, you will need schematics for the machine, but it seems the board with the green lights is the motor drives combined in one board, the one at the right side is the motion control board and the small one should be some termination boards for inputs and out puts.
    So at this stage you are pretty sure the board is faulty, right? No way to take it down send to them and they repair for cheap?
    If the answer to previous is no, then you need to ask them for the schematics so we see what type of signals it sends to drives, at what voltage and so on, also what else it does and what cables enter and go out from the board. Now somebody experienced with retrofits in your area could figure which is which and what is what very fast.
    If they don't send you the schematics the thing to do is see motors name plate, figure motor size, figure at what voltage are driven / transformer output/ rip all out and fit all in one board like that MX3660, its breakout board and 3 drivers integrated. Its LPT compared to the one i said before which is Ethernet but has drives integrated and from all reports is a very nice combo.
    Does the Hf spindle has some control box? where the cable to the spindle is coming from?
    All 3 motors have these numbers in common: 190\500ST-MTR
    X axis has more info....
    Y200-2240-0410 AY04. no idea if thats any clearer.
    At this point I havent got a picture of the spindle wiring - pos tomorrow.
    However it's probably a good idea to either get you over from Spain (!) or find a local engineer. Assuming an engineer will charge minimum £500 + controller £250 + software £150 I just wonder if its all going to get a bit near the cost of a motherboard from Boxford?!
    No such big deal as you think. from all it seems the original board is so expensive, as its separate stand alone motion control.
    Ok, at least for now we have the motors identified and know at what V/A could be driven,
    HYBRID STEPPING MOTORS HY / HS / HN Series
  1. GEC Gemini spindle drive from Boxford 260 VMC
    By Roadrunna in forum Boxford Vertical Mills
    Last Post: 21-09-2021, 12:14 AM
  2. FOR SALE: Boxford A3 HSRI 3D High Speed Router
    Last Post: 18-06-2021, 09:03 PM
  3. Boxford VMC 260 Z axis removal? Any ideas?
    By Roboteernat in forum Boxford Vertical Mills
    Last Post: 19-03-2015, 07:10 PM
  4. Ideal computer for Boxford A3 HSRi?
    By Tom Aylwin in forum Computer Hardware
    Last Post: 21-10-2014, 05:10 PM
  5. spindle bearings overheating
    By Andrew Wilding in forum Spindles & Drive Motors
    Last Post: 15-05-2011, 01:21 PM
