    Does the Hf spindle has some control box? where the cable to the spindle is coming from?
    All 3 motors have these numbers in common: 190\500ST-MTR
    X axis has more info....
    Y200-2240-0410 AY04. no idea if thats any clearer.
    At this point I havent got a picture of the spindle wiring - pos tomorrow.
    However it's probably a good idea to either get you over from Spain (!) or find a local engineer. Assuming an engineer will charge minimum £500 + controller £250 + software £150 I just wonder if its all going to get a bit near the cost of a motherboard from Boxford?!
    No such big deal as you think. from all it seems the original board is so expensive, as its separate stand alone motion control.
    Ok, at least for now we have the motors identified and know at what V/A could be driven,
    HYBRID STEPPING MOTORS HY / HS / HN Series
  1. GEC Gemini spindle drive from Boxford 260 VMC
    By Roadrunna in forum Boxford Vertical Mills
    Last Post: 21-09-2021, 12:14 AM
  2. FOR SALE: Boxford A3 HSRI 3D High Speed Router
    Last Post: 18-06-2021, 09:03 PM
  3. Boxford VMC 260 Z axis removal? Any ideas?
    By Roboteernat in forum Boxford Vertical Mills
    Last Post: 19-03-2015, 07:10 PM
  4. Ideal computer for Boxford A3 HSRi?
    By Tom Aylwin in forum Computer Hardware
    Last Post: 21-10-2014, 05:10 PM
  5. spindle bearings overheating
    By Andrew Wilding in forum Spindles & Drive Motors
    Last Post: 15-05-2011, 01:21 PM
