    Hi all,
    been having a clear out over the past few weeks. Most of the bits have been used very little or not at all. See photos and prices below:
    Dropsa Italian manual oil pump.
    used on my first conversion that has been retired. Total use in hours would be around 40. Very good condition all round and top quality. 5cc per stroke, 500cc capacity. Really good piece of kit. Will take £40 posted to the UK.
    Chinese manual oil pump with 8cc output and 400 cc capacity, as used on some oriental knee mills. Never fitted but been moved around the garage a few times so slightly scratched. £40 posted to the UK
    Magnetic brake HUCO 1705-2421, originally bought for a lathe ATC. Never used, runs on 24Vdc. "Designed to decelerate or hold inertial loads when the voltage is turned off." This brake cost me way too much from RS (£190) so passing it on to however would like it for £85 posted to the UK. Datasheet can be found here: http://docs-europe.electrocomponents...6b800802ae.pdf
    100mm Digital scales with mini USB type serial output form Arceurotrade. Brand new and unused with fittings. Bought to fit a mini lathe but never got round to doing it. They are compatible with Arc's remote digital readout.
    Arc is selling these for £19.69 currently. Will accept £12 including postage each. If you buy both, I will accept £20 posted.
    Send me a message if interested in any of these.
    Regards
    George
    https://emvioeng.com
    I will take the scales please.
    Pm me for payment arrangements etc.
    Scales have been posted.
    Chinese pump now sold.
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 18 Hours Ago Has a total post count of 302. Received thanks 30 times, giving thanks to others 13 times.
    Hi interested in the Dropsa pump can you PM me your details if still avallable please.
    Phill
  1. Building 2nd machine smaller one
    By Timo in forum Gantry/Router Machines & Building
    Last Post: 10-06-2014, 03:10 AM
  2. Thinking of buying/building machine for PCB milling
    By njh in forum Marketplace Discussion
    Last Post: 11-10-2013, 07:35 PM
  3. Musings on building a workshop and a new machine...
    By irving2008 in forum Workshop & Equipment
    Last Post: 19-10-2012, 06:44 AM
  4. NEW MEMBER: CNC and other Machine Building Berlin
    By Andikid in forum New Member Introductions
    Last Post: 07-10-2010, 11:30 PM
