Thread: PIC Advice For A Newbe
Good Day All.
As the title says I am looking for advice with regards to programming PIC's.
To date the only kind of PIC's I have worked with are called PicAxe.
Due to the design and build in software thease PIC chips are to slow for what I am after.
I am looking at building my own PIC based stepper motor driver board.
I am looking to use one PIC per axis total of 3 axis on my board.
Each axis will have the following inputs and outputs.
Inputs
Enable.
Step.
Dir.
Mode Select 1.
Mode Select 2.
Outputs
Coil A.
Coil B.
Coil C.
Coil D.
Fan.
Enable LED.
Step LED.
Dir LED.
So I am going to need a PIC chip with at least 5 inputs and 8/9 outputs.
I am only looking at driving the stepper motors as unipolar.
The mode select switches will be for Full, Wave, and Half Mode stepping, I don't want to go down the micro stepper route yet.
I will be using this driver board with the Mach3 software.
Here are the two related posted on the PicAxe forum.
[ame="http://www.picaxeforum.co.uk/showthread.php?t=11593"]3 Axis Stepper and Spindle Control Circuit Diagrams[/ame].
and
[ame="http://www.picaxeforum.co.uk/showthread.php?t=12324"]1-5us pulse capture[/ame].
I have made a little box to put the driver board into.
Thanks for your time.
Best Regards.Last edited by Mad Professor; 07-06-2009 at 09:14 AM.
07-06-2009 #2
I can't really assist you with your PIC selection (though you've not really any specific h/w needs...eg PWM, USARTS etc ....so I'd imagine most of the PIC 18 range would suffice), but just wanted to chime in as another recent PIC novice/convert.
I'm using my PIC to control just one stepper motor - this stepper is used as a way of traversing enamelled wire onto a coil winding motor. Basically, the main DC motor has an encoder disk. The PIC counts the stripes from this disk & every x stripes (to work out how far it has travelled) it then sends out a pulse to the stepper.
I actually went the simple/lazy way & used a dedicated IC to hadle to stepper interfacing - a UCN5804.
You project sounds really interesting - good luck!
07-06-2009 #3
Thanks for your reply.
I did not want a boring front on my control box, yes it is a little over the top.
I was looking at the F16 / F18 range of the PIC's.
As you already said I don't need PWM, ADC, Ect.
I will be buying the PIC's from RS.
I am not going to buy any pic or parts to build the driver boards unto such time that I know I can build the board and program the PIC to do what I want / need, as I could safe the money to buy a prebuilt driver, but it's not liky to find a driver board with all the led and fan control I am looking for.
The picaxe's that I have been using upto now are programed in something that is very close to Basic.
With the picaxe chips you don't need to buy the software or magic programmer.
I have been looking around the internet and I see there are meny languages for the pic, Basic, C, C++, Pascal, Ect.
As the picaxe was based around the Basic language, so a quick google found "MELabs PICBASIC Compiler" but this is a paid software,
PICBASIC Compiler - meLabs £68.94
and
PICBASIC Pro Compiler - melabs £195.44.
That seems like alot of money to splash out for possibly a one time use.
07-06-2009 #4
07-06-2009 #5
Hi
Love the box and I think I know what you're trying to achieve with the pics, however I think you are over-complicating matters by trying to go that route. I think you may be better having a look at various stepper-drive IC datasheets eg: http://www.robotstorehk.com/5804.pdf these or others may provide the functionality you require already built-in.
As for your progression to Pics your 3 main choices of language would be basic, assembler and 'C'.
Regards
Dave
07-06-2009 #6
MP, (got a name?)
I suggest you get a PICKIT2 and program in PIC assembler (I don't think the PIC is really suited to a HLL) with MPLAB. As to choice of PIC, there are many (too many?) that'll do the job, I suggest you pick one with more I/O and internal resources than you need (you're not buying millions, so the difference in cost between that and one that'll just do the job is pennies).
I know you're re-inventing the wheel, but hey, we all know we could improve on round...
07-06-2009 #7
Thanks for the info.
I see on the Microchipdirect web site: PICkit 2 Starter Kit (DV164120) £35.45
Is this the best / cheapest place to buy one from?
I am just watching some PIC Programming videos on YouTube.
07-06-2009 #8how long is a piece of string?Is this the best / cheapest place to buy one from?
I picked up a Pickit2 from Microchip with 16F887 development board in a promo last year for <£10 delivered, so keep your eyes open for promo's
They flog the PK2 programmer on its own for £25 + carriage + VAT.
http://www.microchipdirect.com/produ...words=pickit+2
There are some very simple DIY PC comport programmers if you want to DIY. You can download the software (MPLAB 8.2 etc.) FOC from the Microchip web site.
[edit]
I think I have stepper driver code for 16 bit pics somewhere, if you want to pinch it.
07-06-2009 #9
Ok thanks.
That’s easy it's double half it's length.how long is a piece of string?
I am just installing the MPLAB as I type.
I will keep my eyes open for a promo.
07-06-2009 #10
Here you go:
It was designed around a 16C84 to drive a L6219 bipolar driver, but since it uses a step table, all you need to do is change the bits to suit your output.
You'll have to change the CPU type etc. to suit whatever PIC you use.
Ignore / delete the limit switch code.
Code:;**************************************** ; PIC Header ;**************************************** ;(c) 1994 - 2008 W.K.Todd Electronics ; ;DATE:23/08/2008 (initialised 27/09/1998) ;FILE:STEPPER.ASM - L6219 STEPPER DRIVER ;VERSION:1.10 - interrupt driven ; ; Target processor = 16C84 (eeprom PIC) ; Assembler = MPASM ; LIST P=16C84 #INCLUDE P16C84.INC ;EQUATES STPCNT EQU 0x0C ;STEP COUNTER FLAGS EQU 0x0D ;VARIOUS FLAG BITS TIMER EQU 0x0E ;GP TIMER USED TO SLOW LOOP ;interrupt service temps STATUS_TEMP EQU 0X2E W_TEMP EQU 0X2F ;BIT ADDRESSES DEBN EQU 0x00 ;DEBOUNCE FLAG CLKIN EQU 0X00 ;CLK INPUT DIRIN EQU 0x01 ;DIRECTION INPUT XLIM EQU 0x00 ;LIMIT SWITCH INPUTS YLIM EQU 0x01 ; ZLIM EQU 0x02 ; LIMIT EQU 0x03 ;LIMIT OUTPUT (ACTIVE HIGH) BYPSWT EQU 0X04 ;LIMIT BYPASS SWITCH ; ORG 0x000 GOTO START ;RESET VECTOR NOP NOP NOP ;INTERRUPT VECTORS TO HERE ; PUSH MOVWF W_TEMP ; Copy W to TEMP register, SWAPF STATUS, W ; Swap status to be saved into W MOVWF STATUS_TEMP ; Save status to STATUS_TEMP register ; Interrupt Service Routine ;test interrupt type BTFSS INTCON,INTF ;test int0 flag goto POPW bcf INTCON,INTF ;clr flag BTFSC PORTB,DIRIN ;TEST DIRECTION GOTO CLKWIZ ;DO ANTI CLK TURN DECF STPCNT,W ;DECR AND FETCH STEP COUNT ANDLW 0x07 ;MODULO 7 MOVWF STPCNT ;SAVE CALL STPTAB ;GET PHASE VALUES MOVWF PORTB GOTO POPW ;AND FINISH ;DO CLOCKWISE TURN CLKWIZ INCF STPCNT,W ;INCR AND FETCH STEP COUNT ANDLW 0x07 ;MODULO 7 MOVWF STPCNT ;SAVE CALL STPTAB ;GET PHASE VALUES MOVWF PORTB POPW SWAPF STATUS_TEMP, W ; Swap nibbles in STATUS_TEMP register ; and place result into W MOVWF STATUS ; Move W into STATUS register ; (sets bank to original state) SWAPF W_TEMP, F ; Swap nibbles in W_TEMP and place result in W_TEMP SWAPF W_TEMP, W ; Swap nibbles in W_TEMP RETFIE ; ; TABLES ;Bits/function ;7 6 5 4 3 2 1 0 ;Io1 I11 PH1 I12 I02 PH2 DIR STEP STPTAB ADDWF PCL,f ;2/3 current, half step table ; RETLW 0xC8 ;STEP0 ; RETLW 0x88 ;1 ; RETLW 0x9C ;2 ; RETLW 0x8C ;3 ; RETLW 0xEC ;4 ; RETLW 0xAC ;5 ; RETLW 0xB8 ;6 ; RETLW 0xA8 ;7 ;full current, half step table RETLW 0xC0 ;STEP0 RETLW 0x00 ;1 RETLW 0x1C ;2 RETLW 0x04 ;3 RETLW 0xE4 ;4 RETLW 0x24 ;5 RETLW 0x38 ;6 RETLW 0x20 ;7 ; ; START OF PROGRAM ; START BSF STATUS,RP0 ;select bank 1 MOVLW 0x03 ;RB0 +1 TO INPUT MOVWF TRISB MOVLW 0x17 ;RA0,1,2,4 TO INPUT MOVWF TRISA MOVLW 0XCF MOVWF OPTION_REG ;set up interrupt BCF STATUS,RP0 MOVLW 0X90 MOVWF INTCON ;enable int0 CLRF STPCNT CLRF FLAGS ;MAIN LOOP MAINLP ;TEST LIMIT SWITCHES TLBPS BTFSS PORTA,BYPSWT ;TEST LIMIT BYPASS GOTO BYPASS MOVF PORTA,W ;GET LIMIT SWITCHES ANDLW 0x07 BTFSS STATUS,Z BSF PORTA,LIMIT ;SET LIMIT IF X,Y OR ZLIM IS HIGH BTFSC STATUS,Z BYPASS BCF PORTA,LIMIT ;CLEAR LIMIT OUTPUT IF SWITCHES ARE ALL LOW GOTO MAINLP ;LOOP BACK END
NEW MEMBER: Newbe on the site
By Phillou in forum New Member IntroductionsReplies: 0Last Post: 14-03-2014, 05:54 PM -
NEW MEMBER: Newbe in France
By dudz in forum New Member IntroductionsReplies: 1Last Post: 17-10-2012, 06:46 PM -
NEW MEMBER: Newbe
By THE PHOENIX in forum New Member IntroductionsReplies: 2Last Post: 03-12-2010, 07:20 PM -
NEW MEMBER: Hi from newbe
By croy in forum New Member IntroductionsReplies: 2Last Post: 28-01-2010, 09:22 PM -
NEW MEMBER: Newbe
By cncezee in forum New Member IntroductionsReplies: 3Last Post: 29-08-2009, 07:40 AM
