  1. #31
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Checking the voltages at the board is far simpler than testing each switch individually.
    If the fault re-occurs, measuring to see if the correct voltage is present at the BOB is the easiest and most accurate way to establish if there's a fault in the E-stop circuit. It could be a faulty input on the BOB, but unless you can confirm there is 5V across the relevant pins when the fault occurs, then you're only guessing where the fault is. It could just as easily be a lose connection somewhere.
  2. The Following User Says Thank You to m_c For This Useful Post:
  3. #32
    Small update to this one... Its now semi solved.
    I realised a few days back that my original attempt at bridging out the estop circuit was a bit flawed. I was using the LEDs on the controller board as an indication of whether the signals were active or not. When I first tried I assumed that the estop would get its power from the machine, but it doesn't. Its powered by usb, unlike the homing and limit switches which are on a 24v power source. The result being that when I bridged, turned on the power at the machine, saw LEDs for the homing / limits but not for the estop I assumed this was still this random estop problem, but it wasn't... it was the fact that I didn't have the usb plugged in.
    I got sent a wiring diagram and realised the mistake... Bridged out the circuit and plugged in and have been milling parts the last few days. It has however STILL estopped on me mid cut, which is a little worrying as there is only a tiny bit of cable bridging the circuit. But just the once and I was able to immediately reset and continue.
    I wouldn't say its solved by any means... For one I have no estop now. I'm dubious that the control card is paying attention to Mach's setting for debounce... I'll have a think / seek advice about trying to rewire to use the 24v power source for the estop and / or add a small capacitor onto the estop circuit to do a bit of debounce the physical way. All things which I'm aware you mentioned ages ago JAZZ .
    Thanks for your help everyone!
  4. #33
    Quote Originally Posted by lateAtNight View Post
    I can't remember yesterday so any advice I gave as well left my puny brain.!! . . . . . . . But I'd be very worried if you have shorted the E-stop and your still losing Motion.!!. . . . . . Wonder what it could be.?????
  1. Sieg - KX1
    By ptjw7uk in forum Milling Machines, Builds & Conversions
    Last Post: 31-07-2016, 11:25 AM
  2. FOR SALE: Sieg x3
    By andris in forum Items For Sale
    Last Post: 25-02-2014, 06:32 PM
  3. CONVERSION: Sieg X2 CNC Conversion
    By A11an in forum Conversion Build Logs
    Last Post: 16-01-2013, 06:06 PM
  4. Sieg KX3
    By gently in forum Milling Machines, Builds & Conversions
    Last Post: 10-09-2011, 11:42 AM
  5. Sieg SX2 in the UK?
    By TheChunk in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2010, 03:00 PM
