I suppose it is worth mentioning once in a while for newbies... if you want to surface anything with an end cutter you need non-plunging tooling.
If your tool cuts all the way to the middle it will leave a graunchy, chewed up line behind when you go sideways
The Following User Says Thank You to Robin Hewitt For This Useful Post:
03-06-2015 #2
I would definately recommend a 1 or 2 flute cutter with a slow spiral, your 4 flute cutter doesnt leave much chip clearance. I would rough first then use the 0.8mm left to finish both sides, very sharp tooling and flood coolant/high pressure air recommended.
The Following User Says Thank You to jamesgates1000 For This Useful Post:
04-06-2015 #3
Hi James,
Many thanks for your help and the pointers. I will try and get some one and two flute cutter for the next job. I had to crack on with what I had for know. Perhaps Trend cutters will be good if you or anyone could provide a cutter reference that would be great so I could the right ones. I have a coolant tank on my mill but know coolant that is another job I will try the compressor though!
All the best
Suesi
04-06-2015 #4
Thank you Robin,
I cut the little job without any balls ups. I was most worried about damaging the machine, cutter or material. That was all fine and the finish will do from the 4 flute for the job in hand. I will get some better cutters perhaps some Trend one and two flute ones.
Many thanks
Suesi
Cnc cutting the wrong size..
By Tomnewry in forum Machine DiscussionReplies: 17Last Post: 25-11-2016, 10:16 PM -
What has gone wrong????
By Davek0974 in forum Plasma Table MachinesReplies: 54Last Post: 05-09-2014, 12:25 AM -
Ok, so whats wrong?
By Davek0974 in forum 3D Printing MachinesReplies: 32Last Post: 27-03-2014, 12:19 PM -
When Home 3D Printing goes wrong lol :)
By Fivetide in forum Machine DiscussionReplies: 0Last Post: 18-08-2013, 04:03 PM -
1605/1610 have they sent the wrong ones?
By kingcreaky in forum Lead Screws, Nuts & SupportsReplies: 4Last Post: 30-07-2013, 09:22 PM
