Thread: Recommend me a Laser cutter.
That it was made in China tells you almost nothing about the quality, TBH - China produces some great stuff as well as total rubbish.
I'm pretty sure it's a Chinese import. You can tell from a few things - the graphic formats it supports, the Chinese character examples work, the control panel and the mention of 'imported' bearing and mirrors.
I heard Epilog and Full Spectrum Laser a lot. As I understand it, Epilog's the Rolls-Royce. Full Spectrum Laser produce something a little more affordable.
One of the less obvious differences is the software that you get with these. There are a lot of complaints about Mochidraw (the stuff that comes with the Chinese ones) but I've seen a few spirited defenses.
Also, if you need features like grayscale engraving, I think the Full Spectrum will and the Epilog definitely can, but the Chinese ones I've seen can't. (From what I've seen, the Chinese ones lack the hardware features you'd want for this - the DSP board has no control over laser power and Mochidraw doesn't support it anyway).
I think what you really need to do is to go see these working.
07-06-2015 #2
Mine has RDworks and works fine withe changes to the power output, you can grey scale no problem. The contorl board inside the machine is specifically made for elaser work and seems very reliable.
Before commiting, do your own research.https://emvioeng.com
Laser cutter, whats the best?
By alex wight in forum General DiscussionReplies: 0Last Post: 20-12-2014, 05:59 PM -
eBay: Laser cutter/engraver
By Bartell in forum Items On eBay UKReplies: 2Last Post: 18-07-2014, 01:30 PM -
1.5mm Mill End Cutter Can Anyone Recommend a Supplier
By Ridgeback in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-01-2013, 12:53 AM -
Laser cutter
By John S in forum Laser Machines & BuildingReplies: 8Last Post: 02-06-2012, 02:16 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM
