No, steel angle is not good, neither U or I profile. Square or rectangle box have much bigger moment of inertia than the before mentioned. 60x60 is minimum, 80x80 is best for normal machine. I prefer 100x100x3 or 4mm, as the bigger the better, but the design must be cleverer also. take a look at my first build, link in signature
No, steel is out of question. You need a mill for this. As a last resort the machine must be fixed gantry with moving bed and short Z. and very very rigid.
You will need 20 size square supported rails /Hiwin or similar/ with the longest bearing blocksblocks, xxxxxHA, not xxxxxCA
Basically with the money you say you have, you can buy the steel, the rails and ball screws and that's all. And thats my advice, make a small 300x300 or up to 400x400mm machine with fixed gantry, invest in proper bearings and ball screws. The slowly finish it whenever possible.
04-06-2015 #2
amd7000
I agree with Silyski. Reviewing what you want to start with:
> 50mm angle iron baseframe and gantry
> Simple bolt together, no lathe/mill etc.
> Steppers and electronics from (big) photocopier
And what you want it to do as a specification:
> 1200x800mm
> Cut wood, aluminium, possibly thin steel
> Hold 0.05mm tolerance
> Be a 'decent' machine
I think you cannot even come close to meeting that specification with the approach you are looking to take. So you have 2 choices -
1. Make a simple 'learning machine' with the 'wrong' bits and get yourself up to speed with what is important etc. Be prepared to write off the hours and costs involved. There is something to be said for this if you go in with that in mind.
2. Actually build a machine capable of what you want (and by the way 0.05mm is tough at this size, even if you do a really good DIY build) by getting some of the bits made for you.
My experience is that I have made 3 major evolutions of cnc machines over the years, with tens of minor improvements to each of them along the way, and I can tell you that I started with a machine a little better than you are proposing (but would not come close to what you want it to do) and worked my way up to a pretty solid machine now (which would almost match what you want to do).
Hope this helps and I know it can be disappointing to be told that something won't work but it is said with the best intentions of having been there, or done that, or seen it done that way and failed.Last edited by routercnc; 04-06-2015 at 12:40 PM. Reason: carraige returns being ignored by webpage!
What 'decent' Milling machine?
By Chaz in forum Milling Machines, Builds & ConversionsReplies: 74Last Post: 21-06-2015, 04:32 PM -
BUILD LOG: My 1st Hybrid Steel/Ally (1150 x 850 work area) (comments/advice please)
By lebies in forum DIY Router Build LogsReplies: 18Last Post: 19-08-2014, 12:00 PM -
eBay: Looks a decent little machine
By EddyCurrent in forum Items On eBay UKReplies: 13Last Post: 12-09-2013, 04:55 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
Already built my machine.. but some pics of work etc
By Yohudi in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-08-2007, 06:15 PM
