Show us what exactly will be the final part. If its a 3d shape you will need a router, not wire cutter.
Boyan, if it's for cutting RC plane foam wing cores then a hot wire cutter (4 axis) is the thing to go for. I'll be making one at some stage (10 years time at my current build rate! !!) For exactly the same use.
