    Don't worry about not understanding the Steps thing as you don't need to understand to work the machine. All you need to check is that the machine returns to Zero. If it doesn't then we'll worry about teaching you all about Steps per etc.
    Regards Knocking the Shuttle then I can't see that being the cause unless you accidentally caught it before pressing cycle start and set one or both the Axis DRO's so a number other than Zero was entered into the DRO's. Then the Zero location would be differant to where you thought it was.
    This is the only explination I can think of because if you was already deep into the material and the DRO changed from Zero to say +/- 5 then the machine would travel side ways.
    Try this in air to see what I mean. Zero the DRO for X & Y then type 10 directly into either DRO. Then type G0 X0 or Y0 depending on which you changed into MDI input line and you'll see it moves sideways for that axis.!!
    Hi Jazz,
    Thank you very much mate for the help and for offering to teach me about the steps if need be.
    I didn't knock the Shuttle prior to the pressing cycle start, and I am sure the X and Y DRO's would have read zero. I guess I just got a little paranoid thinking perhaps I knocked it at the point when things went wrong. I will make the checks you suggested and then if nothing show I think carry on with great caution! The tips you have given me and the thought you have given my issue have provided some reassurance.
    All the best
    Suesi
    Hi Jazz,
    I thought I would thank you for your help and let you know how I got on. I struggled to check the connections to the balls screws as there is a casting for the stepper in the way and I was not sure about taking things apart I don't understand. I set a dial gauge up (a 1" second-hand one made in China) setting the x and y to zero with the G0 moves you suggested for the x and y, the needle fell each time no further out than a thou graduation so I am assuming that is pretty good. Do you think that takes away the worry of perhaps loosing step and the coupler issue? The dial gauge is perhaps not perfect. I could attach a picture of the motor mounts if you thing I should investigate further.
    Thanks ever so much you have helped me a lot.
    Suesi
  1. FOR SALE: Denford Triac
    By asto in forum Items For Sale
    Last Post: 07-02-2016, 08:28 PM
  2. eBay: Excel machine vice taken off a Denford Triac
    By jamesgates1000 in forum Items On eBay UK
    Last Post: 20-10-2015, 07:30 AM
  3. FOR SALE: Denford Triac Bench Milling Machine
    By Binary in forum Items For Sale
    Last Post: 17-10-2014, 09:06 AM
  4. eBay: Denford Triac CNC milling machine mill mach3
    By Fivetide in forum Items On eBay UK
    Last Post: 19-11-2012, 01:46 PM
  5. WANTED: Denford Triac
    By edwardsjc in forum Items Wanted
    Last Post: 20-08-2012, 08:17 AM
