"Plugged in" or "Wired in"? And with what cable running to the shop?
If your machine can draw enough current to throw the breaker is it possible that you're getting mains voltage drop in your shop when the mill is running?
Ideally you should have a breaker on the wall which will trip before the mill can throw the supply breaker,
Regards,
Nick
The Following User Says Thank You to magicniner For This Useful Post:
06-06-2015 #2
Hi Nick,
Thank you for your msg. What I have is a two way socket in a shed in that has a plug in circuit breaker, from there I have approximately 70 meters of 1.5mm 3 core cable to a container where I have my machine plugged in just the normal 3 pin plug. I only have one machine in the container so I am not running lathes, saws or any other machines just the mill. I used the circuit breaker in hope it would help protect my mill.
Many thanks
Suesi
FOR SALE: Denford Triac
By asto in forum Items For SaleReplies: 19Last Post: 07-02-2016, 08:28 PM -
eBay: Excel machine vice taken off a Denford Triac
By jamesgates1000 in forum Items On eBay UKReplies: 0Last Post: 20-10-2015, 07:30 AM -
FOR SALE: Denford Triac Bench Milling Machine
By Binary in forum Items For SaleReplies: 3Last Post: 17-10-2014, 09:06 AM -
eBay: Denford Triac CNC milling machine mill mach3
By Fivetide in forum Items On eBay UKReplies: 0Last Post: 19-11-2012, 01:46 PM -
WANTED: Denford Triac
By edwardsjc in forum Items WantedReplies: 13Last Post: 20-08-2012, 08:17 AM
