07-06-2015 #13
Hi Jazz,
I thought I would thank you for your help and let you know how I got on. I struggled to check the connections to the balls screws as there is a casting for the stepper in the way and I was not sure about taking things apart I don't understand. I set a dial gauge up (a 1" second-hand one made in China) setting the x and y to zero with the G0 moves you suggested for the x and y, the needle fell each time no further out than a thou graduation so I am assuming that is pretty good. Do you think that takes away the worry of perhaps loosing step and the coupler issue? The dial gauge is perhaps not perfect. I could attach a picture of the motor mounts if you thing I should investigate further.
Thanks ever so much you have helped me a lot.
Suesi
FOR SALE: Denford Triac
By asto in forum Items For SaleReplies: 19Last Post: 07-02-2016, 08:28 PM -
eBay: Excel machine vice taken off a Denford Triac
By jamesgates1000 in forum Items On eBay UKReplies: 0Last Post: 20-10-2015, 07:30 AM -
FOR SALE: Denford Triac Bench Milling Machine
By Binary in forum Items For SaleReplies: 3Last Post: 17-10-2014, 09:06 AM -
eBay: Denford Triac CNC milling machine mill mach3
By Fivetide in forum Items On eBay UKReplies: 0Last Post: 19-11-2012, 01:46 PM -
WANTED: Denford Triac
By edwardsjc in forum Items WantedReplies: 13Last Post: 20-08-2012, 08:17 AM
