    it cuts real nice , carbide bits work great
    i cut around 3000mm/min at 12-15k rpm , 3mm doc on a 6mm end mill
    finishing, i try use .3mm stepover or less , but it sands and polishes real easy, just go thru all your grades of paper starting at 220 grit up to 2000 grit
    cant think of any do's and donts :S
    Thanks for the info,
    Been playing with bits of Corian today and been well impressed and as you say polish out scratches and edge cuts easy,
    I have used Carbide and HSS bits both have performed well.
    I looked at the COSSH sheet for harmfull dust etc nothing really to worry about,
    Golden stuff
    Regards
    John
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    Don't use bits that have cut mdf or plywood. Use bits for Corian only, and they'll last longer.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. Cutting Ply/MDF
    By Leadhead in forum Wood Finishing Tips & Tricks
    Last Post: 02-10-2013, 01:59 PM
  2. Cutting Fluid
    By Web Goblin in forum Swarf & Chip Management
    Last Post: 12-01-2013, 09:31 PM
  3. Corian and similar products
    By Fivetide in forum General Discussion
    Last Post: 20-10-2012, 03:36 PM
  4. looking for Corian
    By luke11cnc in forum General Discussion
    Last Post: 26-07-2012, 08:32 AM
  5. First Corian Lithopane
    By audioandy in forum General Discussion
    Last Post: 06-07-2010, 07:04 PM
