05-06-2015 #20
Yep I do, I disagree though, Jess didn't respond to you in the same way you did to him, so while it may have been the way you perceived it, that doesn't mean your perception of it was correct or the intension of Jess.
You don't need to occupy your judgment with troll like behaviour, that's my job and i'm here for you :), I've said it before, I'm not here to manage peoples personalities - it's their behaviour I'm watching out for and I will step in on behalf of any of you if I think its required.
Allot of thought went into the forum guidelines, a little movement either side of the "line" I'm confident we can all live with from time to time, rude and/or personal comments are way way way to far over the line of acceptable.
We all know this Dean and thank you for your commitment to helping others, for a very high percentage of your commitment to others, you are able to do so without the need to cross to far over the "line", just because you think it, doesn't mean you have to say it, the point I'm trying to make is, your better than that
Cool, I cant say I gave your motivations any thought, past what I already know of you generally. What I would say is, given the success you have in helping others...its ok to feel good about yourself
.MeLee
USB/Ethernet controller for Mach3/4 advice
By paulus.v in forum Control Hardware & SystemsReplies: 17Last Post: 17-02-2015, 09:37 PM -
CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
By Greeny in forum Control Hardware & SystemsReplies: 20Last Post: 14-11-2013, 11:59 PM -
USB and Ethernet Mach3 motion controller PLCM-E3
By Purelogic R&D in forum Manufacturer NewsReplies: 39Last Post: 29-12-2012, 09:38 AM -
Pros and cons of climb milling in wood
By Richie in forum Wood Finishing Tips & TricksReplies: 15Last Post: 14-06-2012, 05:09 PM -
Types of Ballnut and preload, questions - pros & cons ?
By Jon S in forum Lead Screws, Nuts & SupportsReplies: 1Last Post: 16-01-2012, 03:39 PM
