  1. #16
    Quote Originally Posted by Jess View Post
    If the communication system was explicitly designed for control purposes, you can! If you want to see a video example, the spindle encoder in the earlier rigid tapping video Dean posted is connected over CANbus. I'm sure that you can also do it over other things like Modbus/RS485 too...but I'm not going to bother finding examples.
    There you go splitting hairs again when you actually don't know the full story or have experience of the controller.!!
    The only reason it's using CANbus because it's a External I/O module that connects to the Main Controller Via CANbus. Hood could have easily connected straight to the main IP-A controller, but with So much I/O to make the Chiron work he's using the I/O Module.!!. . . The Controller still does all the Work and number crunching. CANbus is just used has an easy and stable way to move I/O modules around large machines to localise I/O and keep short Signal wire runs. Other wise it would mean running long signal wires back thru machines risking EMF issues.
    Yeah, I saw the jester, but I'm afraid that it didn't entirely put my mind at ease at the time. I guess I'm jaded, heard too many 'jokes' where someone's actually a bit more serious than they're letting on etc., If I actually knew you, of course, I'm sure my interpretation would have been totally different!
    Rest assured your not and never where in any Danger from me ***REMOVED***. And if you was I'm not stupid enough to post my intentions on a Forum. ***REMOVED***
    MODERATED: Section 2 of the Community & Forum Guidelines, points 5 & 6.
    What you should NOT do:
    • Discuss or link to objectionable and/or offensive topics. This is not permitted and includes but is not limited to: things of a violent nature, pornography, sexism, racism and/or other discriminatory subjects, this includes things considered to be as a “joke”. Religious and/or political discussions or anything considered to be of the same nature are not appropriate for these forums and will be removed from public viewing.
    • Create threads and/or posts deemed to be soliciting any kind of harassment, discrimination, flaming, trolling and/or behaviour considered by the site staff as intentionally abusive or inappropriate. Such content will be removed from public viewing.
  1. USB/Ethernet controller for Mach3/4 advice
    By paulus.v in forum Control Hardware & Systems
    Last Post: 17-02-2015, 09:37 PM
  2. CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
    By Greeny in forum Control Hardware & Systems
    Last Post: 14-11-2013, 11:59 PM
  3. USB and Ethernet Mach3 motion controller PLCM-E3
    By Purelogic R&D in forum Manufacturer News
    Last Post: 29-12-2012, 09:38 AM
  4. Pros and cons of climb milling in wood
    By Richie in forum Wood Finishing Tips & Tricks
    Last Post: 14-06-2012, 05:09 PM
  5. Types of Ballnut and preload, questions - pros & cons ?
    By Jon S in forum Lead Screws, Nuts & Supports
    Last Post: 16-01-2012, 03:39 PM
