07-06-2015 #24
See this is the point.!! . . . . I've used the uc300 and it was fine. Untill you turned some high frequency device on near by then it would freakout. (In the USS case next Room.!!)
Yes it can be said it's the Cards fault not USB protocol but this doesn't happen with Ethernet driven devices I've used. They handle EMF and such crazyness much better in my experience.
I'm not into communication and all that goes with it. But I am into CNC and all that goes with that and I know thru experience that Ethernet is better than USB when it comes to running a CNC machine using Mach3..!! . . . Which is what started this whole Hang bag stuff in first place.!
It's just some people have to twwist words and things around to suit there own Ego's!!Last edited by JAZZCNC; 07-06-2015 at 12:21 PM.
USB/Ethernet controller for Mach3/4 advice
By paulus.v in forum Control Hardware & SystemsReplies: 17Last Post: 17-02-2015, 09:37 PM -
CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
By Greeny in forum Control Hardware & SystemsReplies: 20Last Post: 14-11-2013, 11:59 PM -
USB and Ethernet Mach3 motion controller PLCM-E3
By Purelogic R&D in forum Manufacturer NewsReplies: 39Last Post: 29-12-2012, 09:38 AM -
Pros and cons of climb milling in wood
By Richie in forum Wood Finishing Tips & TricksReplies: 15Last Post: 14-06-2012, 05:09 PM -
Types of Ballnut and preload, questions - pros & cons ?
By Jon S in forum Lead Screws, Nuts & SupportsReplies: 1Last Post: 16-01-2012, 03:39 PM
