    Venturi vacuum generator - https://vacuumtables.co.uk/vacuum-pu...compressed-air
    The first link I posted includes them in the kit, but they are a pretty simple thing, and I'm sure there are plans available to make one for not much money.
    Ah, I ignored the kit link on the basis I have a pump (I'm currently overed from head to foot in Ali-oxide from dremelling 4 years of oxidation from the pump - motor was stalled from lack of use but generally banging it about it's sprung back to life). I have a manometer - came with the pump.
    Venturi?, need a continuous airflow?, I suppose a NRV could help, but think I'll stick with the pump and a low-pressure switch. I've looked at the tables in the link - I think they'd work very well with sheet materials that would cover the vac table but I'm likely to want to play with fairly small boards (100x75) - think I need a table with smaller vacuum zones, so already looking at aquatic 4mm adjustable manifolds, miniature pipe benders and brazing kits. Well... it is the holiday season!
    Lives in East Lothian, United Kingdom. Last Activity: 5 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,970. Received thanks 369 times, giving thanks to others 9 times.
    Have a look at the video on the table page - https://vacuumtables.co.uk/vacuum-ta...table-vt2012-r
    They come with a length of black beading/gasket that you fit to the slots, so you can reduce the vacuum area to just the size you need.
    Pierson Workholding have some good videos on how to use vacuum tables - https://www.youtube.com/playlist?lis...D1tNNi9COAyVlt
    It's worth noting, you don't need to butt the gasket end to end. If you're not using the maximise size of the table, you can get away with running the two ends through the same corner from opposite directions.
  1. MSC Clamp set offer
    By mekanik in forum Workshop & Equipment
    Last Post: 12-01-2015, 07:25 PM
  2. what's the name of this clamp and where to get it in the UK
    By dsc in forum Tool & Tooling Technology
    Last Post: 27-12-2014, 02:06 AM
  3. Vacuum pump for a large matrix bed cnc 5 by 10 foot
    By gavztheouch in forum General Electronics
    Last Post: 03-11-2013, 06:01 PM
  4. Changes a foot????
    By Swarfing in forum General Discussion
    Last Post: 29-06-2013, 10:44 PM
  5. Step clamp
    By Lee Roberts in forum Programmers Corner
    Last Post: 14-10-2008, 02:39 AM
