Page 1 of 3 123 LastLast
    Have you seen that? Its some new contraption. What are your thoughts?
    I have seen similar but actuated by air and bigger, have seen rollers. I wonder how to suck the chips so the bearing balls could roll. May be blow away constantly the dust. I see a possibility that this could be very useful if the dust is evacuated somehow.
    http://www.aliexpress.com/item/Free-...08.4.11.lCkg65
    Looks very similar to a very old design for keeping constant torch height for plasma cutting/marking thin plate when the machine did not have thc.
    Agree. I was thinking more of a usfull for engraving big sheets of thin material, where the material is fixed at extremities but no vacuum table
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,971. Received thanks 369 times, giving thanks to others 9 times.
    I'm thinking it could probably have uses on thin material where a vacuum bed is not available.
    ha ha, thinking the same at the same moment
    Exactly, I have more or less thought about the same thing/design in my head for working with thin wood sheets, 4, 6, 9mm ply and so on, this design isnt a bad one, for mine i considered bigger balls though and just LM type bearing units with round rail - manual adjustment.
    .Me
    .Me
    The most useful i have seen till now are 2 gantry wide rollers that pneumatically actuate and roll in front and at back of spindle. A bit of overkill for home use though. Otherwise would have implemented them already in my OTT build
    These are the units I was thinking about, didn't get as far as size just "head thoughts" to date but it's not complex design...
    Edit: http://m.ebay.co.uk/itm/291159321989
    .Me
    .Me
    if they are big enough and spring included somehow.
    these were the ones in my mind
    Well for spring I thought about just putting some on the linear rail that supports those units, adjust the spring as needed...job done
  1. MSC Clamp set offer
    By mekanik in forum Workshop & Equipment
    Last Post: 12-01-2015, 07:25 PM
  2. what's the name of this clamp and where to get it in the UK
    By dsc in forum Tool & Tooling Technology
    Last Post: 27-12-2014, 02:06 AM
  3. Vacuum pump for a large matrix bed cnc 5 by 10 foot
    By gavztheouch in forum General Electronics
    Last Post: 03-11-2013, 06:01 PM
  4. Changes a foot????
    By Swarfing in forum General Discussion
    Last Post: 29-06-2013, 10:44 PM
  5. Step clamp
    By Lee Roberts in forum Programmers Corner
    Last Post: 14-10-2008, 02:39 AM
