Thread: dual drive x-axis?
10-06-2009 #14No they can't slip; theres two cables, one from left/rear to right/front the other from right/rear to left/front.I would be concerned about slippage,
Basically, if say, the left side moves forward, it pulls on the cable which pull the right side forward it the right side moves it pulls the left side.
As long as the cable tension is maintained (e.g. by a spring) the gantry cannot twist or 'rack'.
6m X axis Rack and pinion or belt drive?
By charlieuk in forum Rack & Pinion SystemsReplies: 6Last Post: 02-07-2020, 01:22 AM -
Dual motor idea!
By Ross77 in forum Motor Drivers & ControllersReplies: 8Last Post: 23-04-2013, 05:07 PM -
WANTED: stepper motor with dual shaft (6mm dia) wanted
By HankMcSpank in forum Items WantedReplies: 1Last Post: 08-04-2013, 12:48 AM -
Heelp! Dual axis steppers.. Losing steps.. Pulling hair out..!
By fasteddy in forum Motor Drivers & ControllersReplies: 9Last Post: 14-05-2010, 02:32 PM -
Which X Axis drive arrangement?
By Glider in forum Linear & Rotary MotionReplies: 0Last Post: 28-02-2010, 11:05 PM
