Thread: dual drive x-axis?
11-06-2009 #28
I hear you, I wouldnt ever use anything but ballscrews. But I like a challenge and am happy to do the math.
Yes the stretch is a product of the load (hookes law not mine) The bit that i dont understand is that if the cable is pre-tensioned and then a load is apllied, is this always an additional load (and therefore more elongation) as the cable is in an elastic state or is only a factor if it is greater than the preload stress?Would the SS cable stretch the same every time? What if it was already tensioned (stretched) ? What if the antistretchyness of the cable was more than the chiploadedness?
if its the later then problem solved, if not can you use plastic design on moving parts?.........
6m X axis Rack and pinion or belt drive?
By charlieuk in forum Rack & Pinion SystemsReplies: 6Last Post: 02-07-2020, 01:22 AM -
Dual motor idea!
By Ross77 in forum Motor Drivers & ControllersReplies: 8Last Post: 23-04-2013, 05:07 PM -
WANTED: stepper motor with dual shaft (6mm dia) wanted
By HankMcSpank in forum Items WantedReplies: 1Last Post: 08-04-2013, 12:48 AM -
Heelp! Dual axis steppers.. Losing steps.. Pulling hair out..!
By fasteddy in forum Motor Drivers & ControllersReplies: 9Last Post: 14-05-2010, 02:32 PM -
Which X Axis drive arrangement?
By Glider in forum Linear & Rotary MotionReplies: 0Last Post: 28-02-2010, 11:05 PM
not me though :lol:
