    Bart's Avatar
    Lives in Krakow, Poland. Last Activity: 08-03-2016 Has been a member for 9-10 years. Has a total post count of 12.
    I bought two HIWIN balscrews and asked seller to machine ends. I've put the long ballscrew (1,3m / 4 feet) into bearing blocks (BF12) and it is stable only in one position (which I guess, means that it is either bent or machining is not concentric).
    Here what's happens when I hand tighten the bearings (2x 7001A - DF cinfiguration). Bearing Block is moving in a circular fashion. When I press it down so that it cant move, ballscrew becomes hard to rotate
    https://www.youtube.com/watch?v=bfo-9KJfJu0
    I know that it's not on a perfectly flat surface - is this the reason for it or it is the ballscrew?
    I've also measured concentricity as shown on the picture below and TIR is around 0,1mm / 0.004" which, I guess, could also mean that bearings are not concentric.
    Any ideas whats wrong?
    And, no I cant put it into gantry yet as I still don't have it :/
    Best regards
    Bart
ID:	15511   Click image for larger version.
Name:	TIR support end.jpg
  1. Looking into a ballscrew, not sure if I should buy. Help
    By oldmam4m80s in forum Lead Screws, Nuts & Supports
    Last Post: 28-07-2017, 10:15 PM
  2. RFQ: Machining mounts in 80x40 profile for FK ballscrew supports
    By Shinobiwan in forum Projects, Jobs & Requests
    Last Post: 20-03-2012, 12:49 AM
  3. Where to get C3 & C5 Ballscrew
    By AdCNC in forum General Discussion
    Last Post: 10-08-2011, 06:56 PM
  4. Machining Ballscrews with a mini lathe (& ballscrew support questions)
    By HankMcSpank in forum Lead Screws, Nuts & Supports
    Last Post: 16-02-2010, 12:22 AM
  5. Ballscrew machining details
    By HiltonSteve in forum Lead Screws, Nuts & Supports
    Last Post: 24-07-2009, 04:01 PM
