    The bedplate is 12mm ecocast. It is mounted in a way that I can adjust in situ then clamp it tight. I use a digital indicator mounted in the spindle and have achieved a parallelism of +/- 0.05mm across the table.
    I didn't like the finish on the ecocast as it showed every little touch (just wiping swarf left marks) so I used a scouring pad + WD-40 to buff if to a uniform bright finish. This can be achieved every time I want to give it a quick polish.
    I am undecided about z-limit. Will have a long look tomorrow.
    Isn't it designed to hard stop? I design Z axis so that it looks it would fell from bearing rails, but in reality at a certain moment the ball screw would stop it up or down so the drive will trip if we come to that.
    So i agree with all, no switches are needed. Plus you have software limits. Plus you are with Lunix so no excuse on part of software.
    Congrats, its a VERY nice build, well done! I can imagine lots of hours going into those great looking alu parts! I just love the neat looks of an all aluminium build. Very good suggestion by Silyavski, maybe put a little block of wood or plastic to hard stop it just to prevent it running off the rails if required and ditch the lower Z switch.
    Sorry, I don't want to stray too far from the topic but since you have first hand experience, whats your opinion of LinuxCNC so far?
    Quote Originally Posted by mitchejc View Post
    Thanks! From start to finish has been around eighteen months which included the control system and liquid cooling. The machining took around 9 months but this is only five hours per week due to work/family commitments. I prefer face-milled aluminium rather than lots of extrusion because it looks nice. Not the fastest way to go, but worth it in the end. It does have a hard-stop, the spindle will not drop onto the table.
    I use Linux a lot (I develop embedded software, drivers etc running on Linux of all flavours) so for me it was a natural choice. I really like LinuxCNC, the work flow I described in the first post has yielded good results although I haven't produced anything that I want to post on this forum yet due to the f*****g limit switch causing random paths to be followed (design flaw, please don't ask - too embarrassing). Today I have drawn up some replacement parts made in acrylic which should fix the problem. I will post a picture when I have my final test piece finished this week.
    Linux is not for everyone as it can be frustrating trying to figure out what you need to know to fix a problem. LinuxCNC, once configured, works very well indeed.
    In a few months I want to dig deeper into BlenderCAM as it can produce some incredible results. The UI on Blender is a bit of a nightmare though and the learning curve is significant so for the moment I am sticking to 2.5D designs.
    Good to know. Are you running via a parallel port BOB or are you using one of the smarter usb/ethernet controllers?
    I have not really looked into it but first prize for me would be if one can run LinuxCNC on the new Raspberry Pi2 to do the trajectory planning and maybe offload the pulse generation to something else. With your experience maybe something you can do for us
  2. Gantry Router
    By stevep in forum Gantry/Router Machines & Building
    Last Post: 04-05-2015, 09:01 PM
  3. Small Gantry Router
    By mike os in forum Gantry/Router Machines & Building
    Last Post: 08-01-2015, 07:02 PM
  4. RFQ: RQF: Router Gantry plates
    By lateAtNight in forum Projects, Jobs & Requests
    Last Post: 27-12-2012, 04:56 AM
  5. BUILD LOG: Fixed Gantry Router
    By lateAtNight in forum DIY Router Build Logs
    Last Post: 28-05-2009, 11:30 PM
