Thread: Vertical laser tube
that is exactly my concern: that all air bubbles will end up on the top of the tube. there must be a reason why its never mounted like that. I searched on the net and could not find a single machine that use this solution so... I think in the end I will just mount it horizontal
31-07-2015 #2
Hi Gianluca, I had the same thoughts as you regarding mounting the tube vertically. I have seen it done somewhere on youtube (can't remember where though).
I think one of the issues would be leverage of the tube on the mounting points unless you secured the entire length to protect the tube. Then if you supported the entire tube, you are putting quite a bit of strain on your gantry (I'm assuming you are thinking of mounting the tube so that it can aim directly into the lens?) with the very rapid movements typically required of a laser cutter (don't know if Moment of Inertia is the right term for the issue I am thinking about).
I am going to incorporate a laser on my non-existant CNC router and it will be horizontal unless the technology changes before I get done.
ClaytLearning, learning, learning! !!
CNC Router Build TBA
01-08-2015 #3
As the previous poster said, keeping the tube from moving will be your biggest issue.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
still battling on...laser tube???
By calida in forum Laser Machines & BuildingReplies: 1Last Post: 17-04-2015, 12:15 PM -
Fix engrave vertical gap or Upgrading laser cutter control card Leetro MPC6515 ?
By Paul Shroom in forum Machine DiscussionReplies: 3Last Post: 18-05-2014, 03:40 AM -
eBay: 40W CO2 Laser Tube + Power Supply + More
By Lee Roberts in forum Items On eBay UKReplies: 0Last Post: 06-12-2013, 08:23 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
FOR SALE: BRAND NEW 120w Reci Laser Tube
By swinds in forum Items For SaleReplies: 14Last Post: 12-04-2012, 08:17 PM
