    Chaz's Avatar
    We have life on all three axis.
    https://www.youtube.com/watch?v=i-B71XsYmLk
    Nothing quick or exciting but executing some g code, slowly.
    Next to do the spindle and home switches.
    Thanks to all that have helped thus far.
    Some bastard, 20 years ago, thought he would be funny by reversing the Z axis encoder ..... explains the odd behaviour that wasn't consistent. Why would it be different to X and Y?
    i2i's Avatar
    remember the need for isolation on the 0-10, there cannot be a connection to ground it must be dc isolated.
    Quote Originally Posted by i2i View Post
    He's good to Go i2i the IP-A 0-10v is isolated. As are all the I/O on the Cslabs controllers.!
    i2i's Avatar
    stunning, they look pretty good, i wish they were about when i had my three phase triac. Saying that i still have the servo's and drives here somewhere, could be good for one of my quatros.
    Chaz's Avatar
    On the topic of isolation, when providing 24V for the purpose of something like a limit switch, should this come from the same 24V that powers the CS Labs unit or one of the outputs of the device itself to try provide some level of isolation?
Name:	Screen Shot 2015-06-24 at 07.48.53.png
ID:	15617   Click image for larger version.
Name:	Screen Shot 2015-06-24 at 07.49.31.png
    Chaz's Avatar
    i2i, I checked the measurements of the missing actuator last night in terms of the 2 threaded elements. The smaller end is M8 but I suspect fine thread. I tried to screw in a standard M8 bolt which it accepted but then stopped.
    The hole size for mounting is just over 21mm, I think on the phone yesterday you thought this might be 27mm ish?
    i2i's Avatar
    i don't remember the m8 thread being fine, and the mounting thread could be 22mm. It's been quite a while since i did one, check the one you have on there.
    For limits Just use the same source that you power the unit with. But if you are keeping full Isolation using a separate source then best pulling from this and powering the unit for it's own personal source.
    Personally I just pull from one source and never had any issues.
  1. FOR SALE: Denford Triac CNC PC
    By ricey3 in forum Items For Sale
    Last Post: 10-01-2017, 01:39 PM
  2. Help Denford triac p.c.
    By mikeulike in forum Denford Mills
    Last Post: 02-06-2015, 03:59 PM
  3. eBay: Denford Triac with Mach3 Conversion
    By large519 in forum Items On eBay UK
    Last Post: 29-04-2015, 05:34 PM
  4. CONVERSION: Denford Triac Mach3 conversion
    By rnr107 in forum Conversion Build Logs
    Last Post: 23-10-2014, 02:44 PM
  5. WANTED: Denford Triac
    By edwardsjc in forum Items Wanted
    Last Post: 20-08-2012, 08:17 AM
