i don't remember the m8 thread being fine, and the mounting thread could be 22mm. It's been quite a while since i did one, check the one you have on there.
24-06-2015 #2
I thought it was M8 fine simply as the standard M8 bolt I have didnt thread, it started and then stopped. Could have been dirt but felt like a different thread.
In terms of the mounting, yes, its around 22mm. The parker units I was looking at seem to be larger, might need to look at another option. RS Components has a number of actuators, not cheap, but have stock and variety.
24-06-2015 #3
RS are expensive for pneumatics, but they're mostly supplying repairers who will pay extra to get a machine back up and running quickly. Parker are also expensive if you're paying full price, but machine builders get quite big discounts, which is why they're so popular.
Try the Norgren catalogue to see if you can match the cylinders - http://www.norgren.com/uk/info/12/actuators
Once you have a part number, try googling it to see who can supply it. I've not used pneumatic actuators for a long time, but the hardest part was always identifying what you need.
There is a possibility the threads could be imperial, so could be worth investing in a couple sets of imperial and metric thread pitch gauges, as pneumatics/hydraulics still use quite a bit of imperial.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
24-06-2015 #4
24-06-2015 #5
Actually, thinking about it last night, when I checked, I was in a rush. I grabbed a bolt which I thought was M8 but I think its M10. Ill measure tonight to be sure. Ive found what I believe to be the same Joucomatic part as what is on the up / down, its also 10mm. The mounting nut is 22mm which is correct.
24-06-2015 #6
These guys will probably have what you want and just over hill in sheffied. . . . http://www.airaccessories.co.uk/
24-06-2015 #7
FOR SALE: Denford Triac CNC PC
By ricey3 in forum Items For SaleReplies: 6Last Post: 10-01-2017, 01:39 PM -
Help Denford triac p.c.
By mikeulike in forum Denford MillsReplies: 3Last Post: 02-06-2015, 03:59 PM -
eBay: Denford Triac with Mach3 Conversion
By large519 in forum Items On eBay UKReplies: 0Last Post: 29-04-2015, 05:34 PM -
CONVERSION: Denford Triac Mach3 conversion
By rnr107 in forum Conversion Build LogsReplies: 11Last Post: 23-10-2014, 02:44 PM -
WANTED: Denford Triac
By edwardsjc in forum Items WantedReplies: 13Last Post: 20-08-2012, 08:17 AM
