These guys will probably have what you want and just over hill in sheffied. . . . http://www.airaccessories.co.uk/
24-06-2015 #2
24-06-2015 #3
OK, the thread is M10 fine for the actuators. M10 x 1.25, all the specs are the same.
24-06-2015 #4
this is weird, the last time i changed one of these i had no problem getting an exact replacement and as low as £12. It was a couple of years ago but there were loads about.
25-06-2015 #5
When I replaced a pneumatic lift ram on my SCM I contacted a company in Derby - SGS - tel no. 01332 576850. I ordered a ram at 4pm on a Friday and was told I could collect at 8 am the next morning. I thought that was fantastic service and the cost was less than 50% of the SCM part, I simply had to tell them the required cylinder dimensions, stroke, force rating and end connection details. I don't know if this helps, but it is probably worth a try. G.
25-06-2015 #6
LOL, take a guess what im doing right now?
http://www.sgs-engineering.com/air-compressors
Snap!
25-06-2015 #7
I was going to order today for delivery tomorrow as Ill be home but didnt get the time and still undecided to what size compressor I need. I dont need much for the pneumatics on the machine but Id like something for cooling too. So looking at a 100L unit. I had a 24L Bambi before, lovely, but expensive and too small for continual air for blowing on parts / clearing swarf etc.
09-07-2015 #8
Ok, time for an update.
Had some setbacks with some of the electronics items, not going to discuss as such but many thanks to continued offline support from both i2i, JazzCNC and Gary @ Zappautomation.
Received my compressor today as well as the solenoid / actuator items. Got mostly working, missing 2 small 90 degree items, but its installed and wired up.
I tested the carousel motor for the first time today, spins along happily. I have no real idea yet how it knows where it is. I know there is a sensor, will try and look at that again later and there is an ability to reverse the direction of travel. Clearly it needs to 'know' which tool is currently selected.
Am hopeful that this weekend, unless I have issues or some delays on parts coming in, may be able to do the the first basic milling, with or without the tool changer working.
FOR SALE: Denford Triac CNC PC
By ricey3 in forum Items For SaleReplies: 6Last Post: 10-01-2017, 01:39 PM -
Help Denford triac p.c.
By mikeulike in forum Denford MillsReplies: 3Last Post: 02-06-2015, 03:59 PM -
eBay: Denford Triac with Mach3 Conversion
By large519 in forum Items On eBay UKReplies: 0Last Post: 29-04-2015, 05:34 PM -
CONVERSION: Denford Triac Mach3 conversion
By rnr107 in forum Conversion Build LogsReplies: 11Last Post: 23-10-2014, 02:44 PM -
WANTED: Denford Triac
By edwardsjc in forum Items WantedReplies: 13Last Post: 20-08-2012, 08:17 AM
