Chaz, if you need any help i can pm you my phone number for a chat about this machine. It's a pretty easy conversion to mach as everything bar the coolant pump will run on single phase and the coolant pump will run off an inverter in delta. I had the same machine here and ran it for ages before i went to a bigger mill.
ps. it looks like all the pneumatic controls are missing, unless they're in the base of the box.Last edited by i2i; 16-06-2015 at 07:28 PM.
16-06-2015 #2
16-06-2015 #3
Great buy Chaz, well done. I have had several Easy/Star/Nova mills and thought the Denford quality very good. You can easily run the coolant pump from 230v single phase in delta using either an inverter or caps (caps are very easy, very cheap). I have never met or spoken to i2i, but have heard from a couple of sources that he has converted quite a lot of Denfords. Good luck with this project. G.
FOR SALE: Denford Triac CNC PC
By ricey3 in forum Items For SaleReplies: 6Last Post: 10-01-2017, 01:39 PM -
Help Denford triac p.c.
By mikeulike in forum Denford MillsReplies: 3Last Post: 02-06-2015, 03:59 PM -
eBay: Denford Triac with Mach3 Conversion
By large519 in forum Items On eBay UKReplies: 0Last Post: 29-04-2015, 05:34 PM -
CONVERSION: Denford Triac Mach3 conversion
By rnr107 in forum Conversion Build LogsReplies: 11Last Post: 23-10-2014, 02:44 PM -
WANTED: Denford Triac
By edwardsjc in forum Items WantedReplies: 13Last Post: 20-08-2012, 08:17 AM
