Ok understand. When I get time i'll take a look at your schematic and Drive manual to see if I can make sense of what you'll need.
My suggestion is to break the conversion down into small parts and not try to eat the whole elephant in one sitting. SO
First concentrate on getting it moving and whats required to do so. Then deal with sundries like ATC and spindle, coolant etc.
There's more work to the ATC than you probably realise because as well has pneumatics you'll need ATC M6 macro writing to suit the controller so it can control the pneumatics and position axis etc in sequence before it can be used correctly. There will be ATC M6 start macros floating around you can use but still 99% chance if you find one it will need modding to suit the IP-A or controller your using.
Coolant etc is easy stuff that is just switched ON/OFF using relays/contactors etc controlled thru outputs and can be added at any time.
Give me a ring if your unsure.!Last edited by JAZZCNC; 18-06-2015 at 12:06 PM.
18-06-2015 #2
Thanks. i2i has indicated he has most / all of these macros.
At present, Im 99% sure the IP-A will work. Im checking wiring and it seems to match. 6 wires for the resolver, 1 ground, 3 for the motor.
Page 36 of the IP-A manual shows what's needed and seems to match page 32 of http://www.irtsa.com/IMG/pdf/me1300re.pdf
The pricing wont hold on the CS Labs, once they are sold out, the price goes back up. Willing to order one now, if its wrong, ill sell it on or try and exchange it later.
18-06-2015 #3
Yes he does but it will still need modding to work with IP-A. Cslabs controllers do alot of things differently to how Mach3 normally works and that's whats makes them good because they do it there way which works much better but it does mean they have dedicated outputs and params etc which will need to be included in the Macro.
Also if the Spindle as an encoder fitted and needs to index for tool holder alignment you'll need CSlabs Encoder module. It probably doesn't but best mentioned.
Yes it will work. Resolver comes from Motor to Drive and as nothing to do with IP-A. Encoder output on Drive goes to Encoder Inputs on IP-A to close the loop between controller and Drive. At the moment you'll find it goes to the Controller that's fitted.
18-06-2015 #4
Thanks, yes, sorry, that's what I meant. I ordered the controller about an hour ago to get it for the weekend on the basis that I was fairly certain it was correct.
Does this controller work with Mach 4?
Which of the modules is the encoder module? Are you able to link it please? Also, how would I know, what do I look for that might be able to indicate if its needed or not?
18-06-2015 #5
Yes and No.
Yes there is a Plug-in for M4 but it's still in Testing phase and not yet 100% stable so I'd recommend you don't Bother.
The good thing is with M4 you can run it along side M3 without interfering with each other so testing M4 is easy if you want to try it and won't wreck your normal working M3 setup.
I've had a quick look at schematic and it's a DC spindle with no sign of encoder so wouldn't worry about it.
18-06-2015 #6
Yes there is a plugging already available for mach 4.
This is the link the encoder module.
http://www.zappautomation.co.uk/elec...io-ip-s-a.html
however, you would typically fit a servo to the spindle to get the best from it for tapping.
If the existing spindle is a high speed spindle, it is unlikely you will be able to tap with it, due to the lack of torque at the lower speeds.
Visit Us: www.automationshop.co.uk
18-06-2015 #7
Thanks both.
Ive installed Mach 3 and 4 to look around. Previously I used Planet CNC which I became familiar with.
Can I test both of these before buying a license (demo period or similar)?
In terms of 4th axis, how difficult, using this IP-A controller, would it be to get the older electronics for a 4th axis? Not sure if its possible to run different controllers or not (irrespective of cost)?
18-06-2015 #8
Yes, you can use Mach3 and 4 in Demo mode. Mach3 has a few features disabled (run from here is main one, but there are a couple others I've forgotten) and has a limit on the number of lines of G-code it'll run. Mach 4 just stops working after a random amount of time and needs restarted.
Regarding testing the servos, find the two wires to the drives that provided the +/-10V input, power up the drives, and using a 1.5V battery in series with about a 100ohm resistor (you can do it without the resistor, but it provides some protection if you happen to try connecting to the wrong wires/pins) connect it across the +/-10V input wires, then try reversing the connection. The servos should turn reasonably slowly in both directions, which lets you know the servos and drives are working.
Another option for a Controller, would be a Dynomotion KFlop + Kanalog combo (along with possibly a Konnect to gain more IO). The Kanalog gives you differential encoder inputs along with analogue inputs and outputs, while still retaining the option to use step/dir. However it is a more complicated controller to setup, and you have order direct from over the pond.
Personally, before you commit to buying a controller, I'd suggest making up a list (I make a spreadsheet) of all the inputs and outputs you're going to need, and what type of input/output i.e. analogue/digital/voltage, along with anything you may like to add in the future.
If you post the list up here, I'm sure people on here will quite happily check it over. Going from your initial list, things like limit switches don't need connected to the controller. Connect them up via the E-stop circuit, with a manual override push switch to bypass them if you do run into them. When you first start, it seems like a good idea to monitor every single switch, but in reality/use, you soon realise it's not needed.
Actually having scanned over your list again, I suspect the top limit switches should actually be the homing switches/sensors, as you also mention over limit switches further down.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
FOR SALE: Denford Triac CNC PC
By ricey3 in forum Items For SaleReplies: 6Last Post: 10-01-2017, 01:39 PM -
Help Denford triac p.c.
By mikeulike in forum Denford MillsReplies: 3Last Post: 02-06-2015, 03:59 PM -
eBay: Denford Triac with Mach3 Conversion
By large519 in forum Items On eBay UKReplies: 0Last Post: 29-04-2015, 05:34 PM -
CONVERSION: Denford Triac Mach3 conversion
By rnr107 in forum Conversion Build LogsReplies: 11Last Post: 23-10-2014, 02:44 PM -
WANTED: Denford Triac
By edwardsjc in forum Items WantedReplies: 13Last Post: 20-08-2012, 08:17 AM
