20-06-2015 #51
So I need to simply bridge between terminal 14 and 15 of the IRTA Drive. What function do I use on the CS Labs unit? Analog Out? Does this push out a voltage or does it simply close a circuit and work as a softswitch?
If I look at the analog out options, I have Analog output 0 (0-10V on pin 7) and Analog output 1 (0-10V on pin 8). I would have thought I needed to use the digital outputs? Sorry, a little bit confused, just want to 'make' a connection between 2 points.
20-06-2015 #52
Actually, from the 15 pin breakout, i dont have a wire to allow a bridge. Something else is holding out the DER relay, need to find that.
This could be changed later but needs rewiring.
20-06-2015 #53
OK, DER Relay working, it was the door latch holding it out.
Drives enabled, no movement yet. Not sure how to configure anything related to steps or similar, do I need to with a servo?
20-06-2015 #54
OK, Y moves when I push in the DER manually. Not sure why - I dont know if the machine is trying to home or something else. If I restart Mach 3, does it 'forget' what it was told before?
Glad ive got movement, not sure whats impacting DER relay yet. It was the door latch, thats sorted, something else is now holding it out. Looking to try and reverse the direction, where is the 'jog wheel' in Mach 3? Ive seen a pic of one, is it a plugin?
20-06-2015 #55
press tab on the keyboard
20-06-2015 #56
20-06-2015 #57
you may be on the limits for any of the three axis, that would keep the estop off.
20-06-2015 #58
20-06-2015 #59
I am finding this saga very interesting.
Keep up the good work .. Clive
20-06-2015 #60
LOL, once its sorted, its easy. Still a lot of stuff to understand but getting there. Movement is an achievement, even if I cant fully control it yet ;p
Now, need to understand all the things that trigger DER relay and then how to reverse direction on these 'analog' servos.
FOR SALE: Denford Triac CNC PC
By ricey3 in forum Items For SaleReplies: 6Last Post: 10-01-2017, 01:39 PM -
Help Denford triac p.c.
By mikeulike in forum Denford MillsReplies: 3Last Post: 02-06-2015, 03:59 PM -
eBay: Denford Triac with Mach3 Conversion
By large519 in forum Items On eBay UKReplies: 0Last Post: 29-04-2015, 05:34 PM -
CONVERSION: Denford Triac Mach3 conversion
By rnr107 in forum Conversion Build LogsReplies: 11Last Post: 23-10-2014, 02:44 PM -
WANTED: Denford Triac
By edwardsjc in forum Items WantedReplies: 13Last Post: 20-08-2012, 08:17 AM
