Page 13 of 25 FirstFirst ... 3111213141523 ... LastLast
  1. #121
    Chaz's Avatar
    Quote Originally Posted by i2i View Post
    you wont need 5, just three. The in/out can be done with one valve, same as the up/down.
    Ah ok thanks, does it have 2 electrical connectors per solenoid then or does it pulse both?
  2. #122
    i2i's Avatar
    when the valve for the horizontal ram is off the carriage is held out under pressure, when it is on the airflow is reversed so the ram pushes the carriage in. Same for the up/down.
  3. #123
    Chaz's Avatar
    We have life on all three axis.
    https://www.youtube.com/watch?v=i-B71XsYmLk
    Nothing quick or exciting but executing some g code, slowly.
    Next to do the spindle and home switches.
    Thanks to all that have helped thus far.
    Some bastard, 20 years ago, thought he would be funny by reversing the Z axis encoder ..... explains the odd behaviour that wasn't consistent. Why would it be different to X and Y?
  4. #124
    One thing to be aware of when using this method, is you have to select caps that will provide reasonably matched voltages between the 3 legs when running. Achieving that with a small motor may prove to be a bit of a challenge, but you should benefit from the fact a coolant pump should have a reasonably steady load.
    My main concern would be that the coolant pump motor is running near it's rated capacity, and when running from a static phase converter you risk burning out the motor if you try running it at high loads.
    I totally agree with the above comments and would add that I check the voltages on each leg and try to get equal voltages under normal load conditions. The run cap value will be determined by balancing the "leg" voltages, and the start cap value (which is usually only switched in for 0.5-1.0 seconds) will assist the motor to start to turn. G.
  5. #125
    i2i's Avatar
    remember the need for isolation on the 0-10, there cannot be a connection to ground it must be dc isolated.
  6. #126
    He's good to Go i2i the IP-A 0-10v is isolated. As are all the I/O on the Cslabs controllers.!
  7. #127
    i2i's Avatar
    stunning, they look pretty good, i wish they were about when i had my three phase triac. Saying that i still have the servo's and drives here somewhere, could be good for one of my quatros.
  8. #128
    Chaz's Avatar
    On the topic of isolation, when providing 24V for the purpose of something like a limit switch, should this come from the same 24V that powers the CS Labs unit or one of the outputs of the device itself to try provide some level of isolation?
Name:	Screen Shot 2015-06-24 at 07.48.53.png
ID:	15617   Click image for larger version.
Name:	Screen Shot 2015-06-24 at 07.49.31.png
  9. #129
    Chaz's Avatar
    i2i, I checked the measurements of the missing actuator last night in terms of the 2 threaded elements. The smaller end is M8 but I suspect fine thread. I tried to screw in a standard M8 bolt which it accepted but then stopped.
    The hole size for mounting is just over 21mm, I think on the phone yesterday you thought this might be 27mm ish?
  10. #130
    i2i's Avatar
    i don't remember the m8 thread being fine, and the mounting thread could be 22mm. It's been quite a while since i did one, check the one you have on there.
  1. FOR SALE: Denford Triac CNC PC
    By ricey3 in forum Items For Sale
    Last Post: 10-01-2017, 01:39 PM
  2. Help Denford triac p.c.
    By mikeulike in forum Denford Mills
    Last Post: 02-06-2015, 03:59 PM
  3. eBay: Denford Triac with Mach3 Conversion
    By large519 in forum Items On eBay UK
    Last Post: 29-04-2015, 05:34 PM
  4. CONVERSION: Denford Triac Mach3 conversion
    By rnr107 in forum Conversion Build Logs
    Last Post: 23-10-2014, 02:44 PM
  5. WANTED: Denford Triac
    By edwardsjc in forum Items Wanted
    Last Post: 20-08-2012, 08:17 AM
